Datasheet HMC1099 (Analog Devices)
Description | >10 W, GaN Power Amplifier, 0.01 GHz to 1.1 GHz |
Pages / Page | 16 / 1 — >10 W, GaN Power Amplifier,. 0.01 GHz to 1.1 GHz. Data Sheet. HMC1099. … |
Revision | A |
File Format / Size | PDF / 395 Kb |
>10 W, GaN Power Amplifier,. 0.01 GHz to 1.1 GHz. Data Sheet. HMC1099. FEATURES. FUNCTIONAL BLOCK DIAGRAM
>10 W, GaN Power Amplifier, 0.01 GHz to 1.1 GHz Data Sheet HMC1099 FEATURES FUNCTIONAL BLOCK DIAGRAM High saturated output power (P D D SAT): 40.5 dBm typical N IC IC IC IC IC IC N G N N N N N N G High small signal gain: 18.5 dB typical 2 1 0 9 8 7 6 5 3 3 3 2 2 2 2 2 High power added efficiency (PAE): 69% typical Instantaneous bandwidth: 0.01 GHz to 1.1 GHz GND 1 24 GND HMC1099 NIC 2 23 NIC Supply voltage: VDD = 28 V at 100 mA NIC 3 22 NIC Internal prematching RFIN/V 4 GG 21 RFOUT/VDD RFIN/V 5 GG 20 RFOUT/VDD Simple and compact external tuning for optimal NIC 6 19 NIC performance NIC 7 18 NIC GND 8 17 GND 32-lead, 5 mm × 5 mm, LFCSP package: 25 mm2 9 0 1 3 APPLICATIONS 2 1 4 5 6 1 1 1 1 1 1 PACKAGE BASE ND IC IC IC IC IC IC N N N N N N ND Extended battery operation for public mobile radios G G
1 0 -0 5
NIC = NO INTERNAL CONNECTION. THESE PINS Power amplifier stage for wireless infrastructures
2
ARE NOT CONNECTED INTERNALLY.
35 1
Test and measurement equipment
Figure 1.
Commercial and military radars General-purpose transmitter amplification GENERAL DESCRIPTION
The HMC1099 is a gallium nitride (GaN), broadband power amplifier delivering >10 W with up to 69% PAE across an instantaneous bandwidth of 0.01 GHz to 1.1 GHz, and with a ±0.5 dB typical gain flatness. The HMC1099 is ideal for pulsed or continuous wave (CW) applications, such as wireless infrastructure, radars, public mobile radios, and general-purpose amplification. The HMC1099 amplifier is externally tuned using low cost, surface-mount components and is available in a compact LFCSP package. Multifunction pin names may be referenced by their relevant function only.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS TOTAL SUPPLY CURRENT BY VDD ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATION CIRCUIT EVALUATION PCB BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
