Datasheet HMC452QS16G, 452QS16GE (Analog Devices) - 7
DescriptionInGaP HBT 1 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Pages / Page22 / 7 — HMC452QS16G / 452QS16GE. InGaP HBT 1 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC452QS16G / 452QS16GE. InGaP HBT 1 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Output IP3 vs. Temperature @ 900 MHz
HMC452QS16G / 452QS16GE InGaP HBT 1 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Output IP3 vs Temperature @ 900 MHz
v01.0205
InGaP HBT 1 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Output IP3 vs. Temperature @ 900 MHz Noise Figure vs. Temperature @ 900 MHz
50 10 48 9 46 8 44 7 42 6 40 GURE (dB) 5 11 +25 C 38 OIP3 (dBm) +85 C 4 SE FI +25 C 36 -40 C 3 +85 C NOI -40 C 34 2 T 32 1 30 0 0.75 0.8 0.85 0.9 0.95 1 0.7 0.75 0.8 0.85 0.9 0.95 1 1.05 1.1 FREQUENCY (GHz) FREQUENCY (GHz) - SM S
Reverse Isolation Gain, Power & IP3 vs. Temperature @ 900 MHz vs. Supply Voltage @ 900 MHz
0 50 45 -5 PLIFIER 40 -10 M +25 C 35 +85 C -15 -40 C 30 Psat (dBm), OIP3 (dBm) 25 Gain ISOLATION (dB) -20 P1dB ER A Psat 20 OIP3 -25 W 15 O -30 10 0.7 0.75 0.8 0.85 0.9 0.95 1 1.05 1.1 4.5 4.75 5 5.25 5.5 GAIN (dB), P1dB (dBm), FREQUENCY (GHz) Vs (Vdc) & P R
Gain, Power & IP3 ACPR vs. Supply Voltage @ 910 MHz
A
vs. Supply Current @ 900 MHz* CDMA IS95, 9 Channels Forward
E 55 -25 50 LIN -30 45 -35 CDMA IS95 Frequency: 910 MHz Gain Integration BW: 1.228 MHz 40 -40 P1dB Forward Link, 9 Channels 5V Psat 35 OIP3 -45 4.5V Psat (dBm), OIP3 (dBm) 5.5V 30 -50 ACPR (dBc) 25 -55 20 -60 15 -65 Source ACPR 10 -70 250 300 350 400 450 500 12 14 16 18 20 22 24 26 28 GAIN (dB), P1dB (dBm), Icq (mA) Channel Power (dBm) * Icq is control ed by varying VPD. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 140
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
