Datasheet HMC452QS16G, 452QS16GE (Analog Devices) - 9
DescriptionInGaP HBT 1 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Pages / Page22 / 9 — HMC452QS16G / 452QS16GE. InGaP HBT 1 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC452QS16G / 452QS16GE. InGaP HBT 1 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Noise Figure vs
HMC452QS16G / 452QS16GE InGaP HBT 1 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure vs
v01.0205
InGaP HBT 1 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure vs. Output IP3 vs. Temperature @ 1900 MHz Temperature @ 1900 MHz
52 10 50 9 48 8 46 7 44 6 42 GURE (dB) 5 11 40 OIP3 (dBm) 4 38 SE FI +25 C +25 C 3 36 +85 C NOI +85 C -40 C 34 -40 C 2 T 32 1 30 0 1.7 1.8 1.9 2 2.1 1.7 1.8 1.9 2 2.1 FREQUENCY (GHz) FREQUENCY (GHz) - SM S
Reverse Isolation Gain, Power & IP3 vs. Temperature @ 1900 MHz vs. Supply Voltage @ 1900 MHz
0 55 50 +25 C 45 PLIFIER -5 +85 C 40 -40 C M 35 -10 30 Psat (dBm), OIP3 (dBm) 25 Gain ISOLATION (dB) 20 P1dB ER A Psat -15 OIP3 15 W 10 O -20 5 1.7 1.8 1.9 2 2.1 4.5 4.75 5 5.25 5.5 GAIN (dB), P1dB (dBm), FREQUENCY (GHz) Vs (Vdc) & P R
Gain, Power & IP3 ACPR vs. Supply Voltage @ 1960 MHz
A
vs. Supply Current @ 1900 MHz* CDMA 2000, 9 Channels Forward
E 50 -25 45 -30 LIN CDMA2000 40 -35 Frequency: 1.96 GHz Integration BW: 1.228 MHz 35 -40 Forward Link, SR1, 9 Channels 30 -45 5V 5.5V Psat (dBm), OIP3 (dBm) 4.5V 25 -50 ACPR (dBc) 20 Gain -55 P1dB 15 Psat -60 OIP3 10 -65 Source ACPR 5 -70 250 300 350 400 450 500 14 16 18 20 22 24 26 28 GAIN (dB), P1dB (dBm), Icq (mA) Channel Power (dBm) * Icq is control ed by varying VPD. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 142
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
