Datasheet HMC454ST89, 454ST89E (Analog Devices) - 5
DescriptionInGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz
Pages / Page12 / 5 — HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 …
File Format / SizePDF / 629 Kb
HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 GHz. Noise Figure. Output IP3 vs. Temperature @ 1960 MHz
HMC454ST89 / 454ST89E InGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz Noise Figure Output IP3 vs Temperature @ 1960 MHz
v05.0710
InGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz Noise Figure Output IP3 vs. Temperature @ 1960 MHz vs. Temperature @ 1960 MHz
44 10 43 9 42 8 41 7 40 6 39 GURE (dB) 5 9 IP3 (dBm) 38 +25 C 4 +25 C +85 C SE FI +85 C 37 -40 C 3 -40 C NOI 36 2 35 1 T 34 0 1.7 1.8 1.9 2 2.1 2.2 1.7 1.8 1.9 2 2.1 2.2 FREQUENCY (GHz) FREQUENCY (GHz) R - SM
Reverse Isolation Gain, Power & Output IP3
E
vs. Temperature @ 1960 MHz vs. Supply Voltage @ 1960 MHz
) W 0 45 O 40 -5 35 +25 C +85 C -40 C 30 -10 R & P 25 PSAT (dBm), IP3 (dBm A -15 20 GAIN PSAT P1dB IP3 E ISOLATION (dB) 15 IN -20 10 5 -25 4.5 4.75 5 5.25 5.5 1.7 1.8 1.9 2 2.1 2.2 GAIN (dB), P1dB (dBm), S - L Vs (V) FREQUENCY (GHz) R IE
ACPR vs. Supply Voltage @ 1.96 GHz ACPR vs. Supply Voltage @ 2.14 GHz
IF
CDMA 2000, 9 Channels Forward W-CDMA, 64 DPCH
L -40 -30 P -45 CDMA2000 Rev. 8 -35 WCDMA M Frequency : 1.96 GHz Frequency : 2.14 GHz -50 Integration BW: 1.228 MHz Integration BW: 3.84 MHz A -40 Forward Link, SRI, 9 CHANNELS 64 DPCH -55 -45 4.5V -60 4.5V -50 5.0V 5.0V -65 ACPR (dBc) ACPR (dBc) -55 5.5V -70 5.5V -60 -75 -65 -80 Source ACPR Source ACPR -85 -70 2 4 6 8 10 12 14 16 18 20 22 0 2 4 6 8 10 12 14 16 18 20 Channel Output Power (dBm) Channel Output Power (dBm) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
9 - 194
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
