Datasheet HMC454ST89, 454ST89E (Analog Devices) - 4
DescriptionInGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz
Pages / Page12 / 4 — HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 …
File Format / SizePDF / 629 Kb
HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 GHz. Broadband Gain & Return Loss @ 1960 MHz
HMC454ST89 / 454ST89E InGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz Broadband Gain & Return Loss @ 1960 MHz
v05.0710
InGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz Broadband Gain & Return Loss @ 1960 MHz Gain vs. Temperature @ 1960 MHz
25 15 20 14 15 13 10 12 5 S21 11 S11 (dB) 0 S22 10 -5 GAIN 9 +25 C +85 C RESPONSE (dB) -10 8 -40 C 9 -15 7 -20 6 -25 5 T 1 1.2 1.4 1.6 1.8 2 2.2 2.4 2.6 2.8 3 1.7 1.8 1.9 2 2.1 2.2 FREQUENCY (GHz) FREQUENCY (GHz)
Input Return Loss Output Return Loss
R - SM
vs. Temperature @ 1960 MHz vs. Temperature @ 1960 MHz
E 0 0 W O -5 -5 +25 C -10 +85 C -40 C -10 R & P -15 A +25 C RETURN LOSS (dB) RETURN LOSS (dB) -15 +85 C E -40 C -20 IN -20 -25 1.7 1.8 1.9 2 2.1 2.2 1.7 1.8 1.9 2 2.1 2.2 FREQUENCY (GHz) FREQUENCY (GHz) S - L R IE
P1dB vs. Temperature @ 1960 MHz Psat vs. Temperature @ 1960 MHz
IF 32 32 L 31 31 P 30 +25 C 30 +85 C M 29 -40 C 29 A 28 28 27 27 26 P1dB (dBm) 26 +25 C PSAT (dBm) +85 C 25 25 -40 C 24 24 23 23 22 22 1.7 1.8 1.9 2 2.1 2.2 1.7 1.8 1.9 2 2.1 2.2 FREQUENCY (GHz) FREQUENCY (GHz) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
9 - 193
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
