Datasheet HMC455LP3, 455LP3E (Analog Devices) - 3
DescriptionInGaP HBT ½ Watt High IP3 AMPLIFIER, 1.7 - 2.5 GHz
Pages / Page6 / 3 — HMC455LP3 / 455LP3E. InGaP HBT ½ Watt High IP3. AMPLIFIER, 1.7 - 2.5 GHz. …
File Format / SizePDF / 376 Kb
HMC455LP3 / 455LP3E. InGaP HBT ½ Watt High IP3. AMPLIFIER, 1.7 - 2.5 GHz. Output IP3 vs. Temperature
HMC455LP3 / 455LP3E InGaP HBT ½ Watt High IP3 AMPLIFIER, 1.7 - 2.5 GHz Output IP3 vs Temperature
HMC455LP3 / 455LP3E
v02.0605
InGaP HBT ½ Watt High IP3 AMPLIFIER, 1.7 - 2.5 GHz Output IP3 vs. Temperature Noise Figure vs. Temperature
44 10 9 42 8 40 7 38 6 GURE (dB) 5 11 36 +25C IP3 (dBm) 4 +85C SE FI +25C 34 -40C 3 +85C NOI -40C 2 32 1 T 30 0 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 FREQUENCY (GHz) FREQUENCY (GHz) - SM S R
Power Compression @ 1.95 GHz Power Compression @ 2.15 GHz
IE 60 60 IF 50 50 L Pout Gain P Pout PAE 40 Gain 40 PAE M 30 30 R A 20 20 E 10 10 Pout (dBm), GAIN (dB), PAE (%) Pout (dBm), GAIN (dB), PAE (%) W 0 0 O -10 -5 0 5 10 15 20 -10 -5 0 5 10 15 20 INPUT POWER (dBm) INPUT POWER (dBm) & P R
Gain, Power & IP3 vs.
A
Reverse Isolation vs. Temperature Supply Voltage @ 1.95 GHz
E 0 44 IN 40 L -5 +25C 36 +85C -10 -40C 32 28 -15 Psat (dBm), IP3 (dBm) 24 Gain ISOLATION (dB) -20 20 P1dB Psat IP3 16 -25 12 -30 8 1.5 1.6 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 4.5 4.7 5 5.2 5.5 Gain (dB), P1dB (dBm), FREQUENCY (GHz) Vs (V) Data shown is tuned for 1.85 - 2.2 GHz, contact HMC Applications for recommended 1.7 - 1.85 GHz & 2.2 - 2.5 GHz tuning circuits. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 236
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
