Datasheet ADL6012 (Analog Devices) - 8
Description2 GHz to 67 GHz, 500 MHz Bandwidth Envelope Detector
Pages / Page24 / 8 — ADL6012. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. +125°C. +105°C. …
File Format / SizePDF / 713 Kb
ADL6012. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. +125°C. +105°C. +85°C. +25°C. –40°C. –55°C. OLTA. T V. 0.1. L V. TIA. 0.01. IFFE. 0.001. –30. –25
ADL6012 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS +125°C +105°C +85°C +25°C –40°C –55°C OLTA T V 0.1 L V TIA 0.01 IFFE 0.001 –30 –25
ADL6012 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 10 10 ) +125°C ) +125°C V V ( +105°C ( +105°C +85°C +85°C GE +25°C GE +25°C –40°C –40°C –55°C –55°C OLTA 1 OLTA 1 T V T V U U TP TP OU OU ± 0.1 ± 0.1 V V N N E E L V L V TIA TIA N 0.01 N 0.01 E E R R IFFE IFFE D D 0.001 0.001 –30 –25 –20 –15 –10 –5 0 5 10 15 20
003
006
PIN (dBm) P
16086-
IN (dBm)
16086- Figure 3. Differential VENV± Output Voltage vs. Input Power (PIN) for Various Figure 6. Differential VENV± Output Voltage vs. PIN for Various Temperatures Temperatures at 2 GHz at 18 GHz
10 10 ) +125°C ) +125°C V V +105°C ( +105°C ( +85°C +85°C GE +25°C GE +25°C –40°C –40°C 1 –55°C 1 –55°C OLTA OLTA T V T V U U TP TP OU OU ± 0.1 ± 0.1 V V N N E E L V L V TIA TIA N 0.01 N 0.01 E E R R IFFE IFFE D D 0.001 0.001 –30 –25 –20 –15 –10 –5 0 5 10 15 20
004
007
PIN (dBm) PIN (dBm)
16086- 16086- Figure 4. Differential VENV± Output Voltage vs. PIN for Various Temperatures Figure 7. Differential VENV± Output Voltage vs. PIN for Various Temperatures at 5.8 GHz at 28 GHz
10 10 ) +125°C ) +125°C V V ( +105°C ( +105°C +85°C +85°C GE +25°C GE +25°C –40°C –40°C 1 –55°C 1 –55°C OLTA OLTA T V T V U U TP TP OU OU ± 0.1 ± 0.1 V V N N E E L V L V TIA TIA N 0.01 N 0.01 E E R R IFFE IFFE D D 0.001 0.001 –30 –25 –20 –15 –10 –5 0 5 10 15 20
005
008
PIN (dBm) PIN (dBm)
16086- 16086- Figure 5. Differential VENV± Output Voltage vs. PIN for Various Temperatures Figure 8. Differential VENV± Output Voltage vs. PIN for Various Temperatures at 10 GHz at 38 GHz Rev. 0 | Page 8 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION BASIC CONNECTIONS RF INPUT ENVELOPE OUTPUT INTERFACE COMMON-MODE VOLTAGE INTERFACE ENABLE INTERFACE DECOUPLING INTERFACE PCB LAYOUT RECOMMENDATIONS SYSTEM CALIBRATION AND MEASUREMENT ERROR APPLICATIONS INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
