2 GHz to 67 GHz, 500 MHz Bandwidth Envelope Detector
Pages / Page
24 /9 — Data Sheet. ADL6012. +125°C. +105°C. +85°C. +25°C. –40°C. –55°C. OLTA. T …
PDF / 713 Kb
Data Sheet. ADL6012. +125°C. +105°C. +85°C. +25°C. –40°C. –55°C. OLTA. T V. 0.1. L V. 0.01. TIA. IFFE. 0.001. –30. –25. –20. –15. –10. PIN (dBm). IN (dBm). E (V). VEN
Data SheetADL6012101)+125°C)VV+125°C(+105°C(+85°C+105°CGE+25°CGE+85°C–40°C+25°C–55°C–40°COLTA1OLTA–55°CT VT V0.1UUTPTPOUOU±0.1±VVNNEEL VL V0.01TIATIAN0.01NEERRIFFEIFFEDD0.0010.001–30–25–20–15–10–50510 009 –20–15–10–50510 012 PIN (dBm)P 16086- IN (dBm) 16086- Figure 9. Differential VENV± Output Voltage vs. PIN for Various Temperatures Figure 12. Differential VENV± Output Voltage vs. PIN for Various at 40 GHz Temperatures at 60 GHz 101+125°C+125°C+105°C+105°CE (V)+85°CE (V)G+85°CGA+25°CA+25°CT–40°CL–40°C1LT–55°C–55°CVOVOTT0.1PUPUTTUUO0.1OV±V±VENVENLL0.01TIATIAN0.01NEERRIFFEIFFEDD0.0010.001–30–25–20–15–10–5051015 010 –20–15–10–50510 013 PIN (dBm)P 16086- IN (dBm) 16086- Figure 10. Differential VENV± Output Voltage vs. PIN for Various Figure 13. Differential VENV± Output Voltage vs. PIN for Various Temperatures at 43.5 GHz Temperatures at 67 GHz 104.03))VV(+125°C(+105°C3.5GEGE+85°C2+25°C1OLTA–40°C3.0OLTA–55°CT VT V1UU2.5TPTPB) dOU0.1OUR (±2.00±VVNNRROEE1.5EL VL V–1+125°CTIA+105°C0.01TIAN1.0N+85°CEERR+25°C–2–40°C0.5–55°CIFFEIFFEDD0.0010–3 1 –30–25–20–15–10–5051015 1 0 00.20.40.60.81.01.21.41.61.82.0 014 PIN (dBm)V 16086- PEAK (V) 16086- Figure 11. Differential VENV± Output Voltage vs. PIN for Various Figure 14. Differential VENV± Output Voltage and Error vs. VPEAK for Various Temperatures at 52 GHz Temperatures at 2 GHz Rev. 0 | Page 9 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION BASIC CONNECTIONS RF INPUT ENVELOPE OUTPUT INTERFACE COMMON-MODE VOLTAGE INTERFACE ENABLE INTERFACE DECOUPLING INTERFACE PCB LAYOUT RECOMMENDATIONS SYSTEM CALIBRATION AND MEASUREMENT ERROR APPLICATIONS INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
