Datasheet ADL6012 (Analog Devices) - 10
Description2 GHz to 67 GHz, 500 MHz Bandwidth Envelope Detector
Pages / Page24 / 10 — ADL6012. Data Sheet. 4.0. 3.5. 3.0. OLTA. T V. 2.5. 2.0. R (. RRO. 1.5. L …
File Format / SizePDF / 713 Kb
ADL6012. Data Sheet. 4.0. 3.5. 3.0. OLTA. T V. 2.5. 2.0. R (. RRO. 1.5. L V. +125°C. TIA. +105°C. 1.0. +85°C. +25°C. –40°C. 0.5. –55°C. IFFE. 0.2. 0.4. 0.6. 0.8. 1.2. 1.4. 1.6
ADL6012 Data Sheet 4.0 3.5 3.0 OLTA T V 2.5 2.0 R ( RRO 1.5 L V +125°C TIA +105°C 1.0 +85°C +25°C –40°C 0.5 –55°C IFFE 0.2 0.4 0.6 0.8 1.2 1.4 1.6
ADL6012 Data Sheet 4.0 3 4.0 3 ) ) V V ( ( 3.5 3.5 GE 2 GE 2 3.0 OLTA 3.0 OLTA T V 1 T V 1 U 2.5 U 2.5 TP B) B) d TP d OU 2.0 0 R ( OU R ( ± 2.0 0 ± V V N N RRO E RRO E 1.5 E 1.5 E L V –1 +125°C L V –1 +125°C TIA +105°C +105°C 1.0 TIA N +85°C 1.0 N +85°C E E R +25°C +25°C –2 R –40°C –2 –40°C 0.5 –55°C 0.5 –55°C IFFE IFFE D D 0 –3 0 –3 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0
015
018
VPEAK (V)
16086-
VPEAK (V)
16086- Figure 15. Differential VENV± Output Voltage and Error vs. VPEAK for Various Figure 18. Differential VENV± Output Voltage and Error vs. VPEAK for Various Temperatures at 5.8 GHz Temperatures at 28 GHz
4.0 3 4.0 3 ) V ( E (V) 3.5 3.5 G 2 GE A 2 T L 3.0 3.0 OLTA VO T 1 T V 1 2.5 U PU 2.5 T B) TP B) U d d O 2.0 0 R ( OU 2.0 0 R ( ± V RRO N RRO E 1.5 E E VEN 1.5 L –1 +125°C L V –1 +125°C TIA +105°C +105°C 1.0 TIA N +85°C 1.0 N +85°C E E R +25°C +25°C –2 R –40°C –2 –40°C 0.5 –55°C 0.5 –55°C IFFE IFFE D D 0 –3 0 –3 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0
016
019
VPEAK (V)
16086-
VPEAK (V)
16086- Figure 16. Differential VENV± Output Voltage and Error vs. VPEAK for Various Figure 19. Differential VENV± Output Voltage and Error vs. VPEAK for Various Temperatures at 10 GHz Temperatures at 38 GHz
4.0 3 4.0 3 ) ) V V ( T ( 3.5 3.5 U 2 GE 2 TP 3.0 3.0 OU OLTA GE 1 T V 1 2.5 U 2.5 B) B) d TP d OLTA V 2.0 0 R ( OU R ( ± 2.0 0 ± V V N RRO N RRO E E 1.5 E 1.5 E L V –1 +125°C L V –1 TIA +105°C +125°C 1.0 TIA N +85°C 1.0 N +105°C E E R +25°C +85°C –2 R –40°C –2 +25°C 0.5 –55°C 0.5 IFFE IFFE –40°C D D –55°C 0 –3 0 –3 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0
017
020
VPEAK (V)
16086-
VPEAK (V)
16086- Figure 17. Differential VENV± Output Voltage and Error vs. VPEAK for Various Figure 20. Differential VENV± Output Voltage and Error vs. VPEAK for Various Temperatures at 18 GHz Temperatures at 40 GHz Rev. 0 | Page 10 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION BASIC CONNECTIONS RF INPUT ENVELOPE OUTPUT INTERFACE COMMON-MODE VOLTAGE INTERFACE ENABLE INTERFACE DECOUPLING INTERFACE PCB LAYOUT RECOMMENDATIONS SYSTEM CALIBRATION AND MEASUREMENT ERROR APPLICATIONS INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
