Data SheetADL6010TYPICAL PERFORMANCE CHARACTERISTICS VPOS = 5.0 V, CLOAD = open, TA = 25°C, unless otherwise specified. Error referred to slope and intercept at indicated calibration points. Single-ended input drive, input RF signal is a continuous sine wave, unless otherwise noted. 1001)–5V (GE0.5GHz 1.0GHzB) dOLTA0.15.0GHz–101 (10.0GHz1T VSU15.0GHzTP20.0GHz 25.0GHzOU0.0130.0GHz–1535.0GHz 40.0GHz 43.5GHz 007 0.001–20 1617- 1 003 –40–35 –30 –25 –20 –15 –10–5051015200.5510152025303540PFREQUENCY (GHz)IN (dBm) 11617- Figure 4. Typical Output Voltage (VOUT) vs. RF Input Power (PIN) at Various Figure 7. Input Return Loss (S11) vs. Input Frequency with Frequencies (0.5 GHz to 43.5 GHz) at 25°C Input Connector and PCB Trace Embedded 10410CALIBRATION AT–26dBm, –14dBm, AND +5dBmPIN = +10dBm30) V21PIN = 0dBmdB –10(1E (V)GEB)GPAIN = –10dBmdLT–20R (00.1OOLTAT VT VRROUUPIN = –20dBmE –1–30TPTP–55°C –40°COUOU–2+25°C0.01PIN = –30dBm+85°C–40+125°C–3–50–40.001 006 0.5510152025303540–30–25–20–15–10–505101520 009 FREQUENCY (GHz) 11617- PIN (dBm) 1617- 1 Figure 5. Output Voltage (VOUT) Flatness vs. Frequency for Five RF Input Power Figure 8. Conformance Error and Output Voltage (VOUT) vs. Values (PIN) RF Input Power (PIN) for Various Temperatures at 0.5 GHz 52.642.4+125°CmA) 2.2E (V)(+85°CG 3ANTLT2.0O+25°CT VCURREU 2Y 1.8LTPVPOS = 4.75VPPOUV–40°CPOS = 5.00VSUV1.6POS = 5.25V1–55°C1.4 004 005 1617- 0 1617- 1 1.2 1 –40–35 –30–25 –20–15 –10–505101520–40–35 –30–25 –20 –15 –10–505101520PIN (dBm)PIN (dBm) Figure 6. Output Voltage (VOUT) vs. RF Input Power (PIN) for Figure 9. Supply Current vs. RF Input Power (PIN) for Various Temperatures Various Supply Voltages
Rev. E | Page 9 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION BASIC CONNECTIONS PCB LAYOUT RECOMMENDATIONS SYSTEM CALIBRATION AND ERROR CALCULATION EFFECT OF A CAPACITIVE LOAD ON RISE TIME AND FALL TIME EVALUATION BOARD EVALUATION BOARD ASSEMBLY DRAWINGS OUTLINE DIMENSIONS ORDERING GUIDE
