Datasheet AD8479 (Analog Devices) - 6
DescriptionVery High Common-Mode Voltage Precision Difference Amplifier
Pages / Page17 / 6 — AD8479. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. REF(–). …
RevisionC
File Format / SizePDF / 396 Kb
AD8479. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. REF(–). –IN. +VS. +IN. TOP VIEW. OUTPUT. (Not to Scale). REF(+). NOTES
AD8479 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS REF(–) –IN +VS +IN TOP VIEW OUTPUT (Not to Scale) REF(+) NOTES
AD8479 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS REF(–) 1 8 NC –IN 2 AD8479 7 +VS +IN 3 6 TOP VIEW OUTPUT (Not to Scale) –V 4 5 REF(+) S
002
NOTES
18-
1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN.
111 Figure 5. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 REF(−) Negative Reference Voltage Input. 2 −IN Inverting Input. 3 +IN Noninverting Input. 4 −VS Negative Supply Voltage. 5 REF(+) Positive Reference Voltage Input. 6 OUTPUT Output. 7 +VS Positive Supply Voltage. 8 NC No Connect. Do not connect to this pin. Rev. C | Page 6 of 17 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS SINGLE-SUPPLY OPERATION SYSTEM-LEVEL DECOUPLING AND GROUNDING USING A LARGE SHUNT RESISTOR OUTPUT FILTERING GAIN OF 60 DIFFERENTIAL AMPLIFIER ERROR BUDGET ANALYSIS EXAMPLE OUTLINE DIMENSIONS ORDERING GUIDE
