Datasheet B220/A, B260/A (Diodes) - 2
Manufacturer | Diodes |
Description | 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER |
Pages / Page | 5 / 2 — B220/A - B260/A. Maximum Ratings. Characteristic. Symbol. B220/A. B230/A. … |
File Format / Size | PDF / 396 Kb |
B220/A - B260/A. Maximum Ratings. Characteristic. Symbol. B220/A. B230/A. B240/A. B250/A. B260/A. Unit. Thermal Characteristics. Value
B220/A - B260/A Maximum Ratings
(@TA = +25°C, unless otherwise specified.) Single phase, half wave, 60Hz, resistive or inductive load. For capacitance load, derate current by 20%.
Characteristic Symbol B220/A B230/A B240/A B250/A B260/A Unit
Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM 20 30 40 50 60 V DC Blocking Voltage VR RMS Reverse Voltage VR(RMS) 14 21 28 35 42 V Average Rectified Output Current IO 2.0 A Non-Repetitive Peak Forward Surge Current, 8.3ms I Single Half Sine-Wave Superimposed on Rated Load FSM 50 A
Thermal Characteristics Characteristic Symbol Value Unit
SMA 25 Typical Thermal Resistance, Junction to Lead R °C/W SMB θJL 20 Operating and Storage Temperature Range TJ, TSTG -65 to +150 °C
Electrical Characteristics
Characteristic Symbol Min Typ Max Unit Test Condition
B220/A, B230/A, B240/A 0.50 Forward Voltage Drop V V I B250/A, B260/A F — — 0.70 F = 2.0A, TA = +25°C 0.5 @ Rated VR, TA = +25°C Leakage Current (Note 6) IR — — mA 20 @ Rated VR, TA = +100°C Total Capacitance CT — — 200 pF VR = 40V, f = 1MHz Note: 6. Short duration pulse test used to minimize self-heating effect. B220/A - B260/A 2 of 5 July 2015 Document number: DS13004 Rev. 22 - 2
www.diodes.com
© Diodes Incorporated
