Datasheet B220/A, B260/A (Diodes) - 3
Manufacturer | Diodes |
Description | 2.0A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER |
Pages / Page | 5 / 3 — B220/A - B260/A. www.diodes.com |
File Format / Size | PDF / 396 Kb |
B220/A - B260/A
) 10 ) 100 A A ( m T ( N T E N R E 10 R R U R C U C D 1.0 R E A S R 1.0 W E R V O E F R S S U U O 0.1 O E 0.1 E N N A T A T N N A A 0.01 T T S S NI NI , I F 0.01 I R 0.001 0 0.2 0.4 0.6 0.8 1.0 0 20 40 60 80 100 120 140 V , INSTANTANEOUS FORWARD VOLTAGE (V) F PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig. 1 Typical Forward Characteristics Fig. 2 Typical Reverse Characteristics 1,000 2.5 ) A( ) T F N 2.0 p( E R E R C U N C A TI D 1.5 C R A A P 100 W A R C O L F 1.0 A T E O G T A , R T E C V 0.5 A , )VA(IF 10 0 0.1 1 10 100 25 50 75 100 125 150 V , DC REVERSE VOLTAGE (V) T , TERMINAL TEMPERATURE (ºC) R T Fig. 4 Forward Current Derating Curve Fig. 3 Total Capacitance vs. Reverse Voltage 160 50 ) C 150 Note 6 A ° Note 7 ( T E 140 N R E 40 U 130 R T A R R 120 U E C P 110 E M G 30 E 100 R T U T 90 S N D EI 80 R B A 20 M 70 W A R D 60 O E F T A 50 K R A 10 E E 40 P D , A 30 M T SIF 20 0 0 4 8 12 16 20 24 28 32 36 40 1 10 100 V , DC REVERSE VOLTAGE (V) NUMBER OF CYCLES AT 60 Hz R Fig. 6 Max Non-Repetitive Peak Forward Surge Current Fig. 5 Operating Temperature Derating (B240) Note: 7. Device mounted on FR-4 PC board with minimum recommended pad layout pattern as per http://www.diodes.com. B220/A - B260/A 3 of 5 July 2015 Document number: DS13004 Rev. 22 - 2
www.diodes.com
© Diodes Incorporated
