Datasheet MLX90392 (Melexis) - 10
ManufacturerMelexis
Description3D Magnetometer
Pages / Page40 / 10 — MLX90392. Parameter. Symbol. Min. Typ. Max. Unit. Conditions. 6.4. …
MLX90392. Parameter. Symbol. Min. Typ. Max. Unit. Conditions. 6.4. Magnetic Specifications
MLX90392 Parameter Symbol Min Typ Max Unit Conditions 6.4 Magnetic Specifications
link to page 10 link to page 10
MLX90392
3D Magnetometer
Parameter Symbol Min. Typ. Max. Unit Conditions
Temperature sensor TRES 48 50 52 LSB16/°C resolution(1) Temperature sensor accuracy TLIN -3 3 °C +/-3sigma Input Level High(2) VIH 56 59 63 %VDD SDA, SCL Input Level Low(2) VIL 43 48 54 %VDD SDA, SCL Input Level Hysteresis VIHYST 5 11 17 %VDD SDA, SCL Input Capacitance(2) Cin 5 10 pF SDA, SCL SDA (Static, 1mA Output Level Low VOL 0.5 1 %VDD load) Output on resistance Rdson 5 8 14 ohms +/-3sigma Output leakage current 0.1 0.3 uA ESD HBM 2 kV All pins ESD CDM 0.5 kV All pins Table 8 – Electrical Operating conditions
Operating Characteristics, TA = -40°C to 85°C (unless otherwise specified)
XY Magnetic sensitivity SENSXY 0.135 0.15 0.165 µT/LSB version xxx-010 1.33 1.5 1.67 version xxx-011 room temperature Z Magnetic Sensitivity SENSZ 0.135 0.15 0.165 µT/LSB version xxx-010 1.33 1.5 1.67 version xxx-011 room temperature Magnetic measurement range BRANGE ±4421 ±4912 ±5403 µT version xxx-010 ±43560 ±49128 ±54696 µT version xxx-011 room temperature version xxx-010 with temperature compensation – 5ms RMS Noise NXYZ conv time 2.2 2.4 µTrms (DIG_FILTXY=3 DIG_FILTZ=4, OSR_HALL=1), room temperature version xxx-010 without temperature compensation N RMS Noise XYZ 1.5 1.7 µTrms 5ms conv time (DIG_FILTXY=3 DIG_FILTZ=4, OSR_HALL=1), room temperature 1 The data format is 2’s complement with 0 lsb corresponding to 0degC 2 This specification relates to the sensor and not the I2C bus Revision 002 – 15 Apr 2021 Datasheet Page 10 of 40 3901090392
