Datasheet ADuM1100 (Analog Devices) - 10
DescriptioniCoupler Digital Isolator
Pages / Page20 / 10 — ADuM1100. Data Sheet. PACKAGE CHARACTERISTICS. Table 4. Parameter. …
RevisionK
File Format / SizePDF / 420 Kb
ADuM1100. Data Sheet. PACKAGE CHARACTERISTICS. Table 4. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions. REGULATORY INFORMATION
ADuM1100 Data Sheet PACKAGE CHARACTERISTICS Table 4 Parameter Symbol Min Typ Max Unit Test Conditions REGULATORY INFORMATION
ADuM1100 Data Sheet PACKAGE CHARACTERISTICS Table 4. Parameter Symbol Min Typ Max Unit Test Conditions
Resistance (Input-to-Output)1 RI-O 1012 Ω Capacitance (Input-to-Output)1 CI-O 1.0 pF f = 1 MHz Input Capacitance2 CI 4.0 pF IC Junction-to-Case Thermal Resistance, Side 1 θJCI 46 °C/W Thermocouple located at center of package underside IC Junction-to-Case Thermal Resistance, Side 2 θJCO 41 °C/W Package Power Dissipation PPD 240 mW 1 The device is considered a 2-terminal device; Pin 1, Pin 2, Pin 3, and Pin 4 are shorted together, and Pin 5, Pin 6, Pin 7, and Pin 8 are shorted together. 2 Input capacitance is measured at Pin 2 (VI).
The ADuM1100 is approved by the following organizations.
Table 5. UL CSA CQC VDE
Recognized Under Approved under CSA Approved under Certified according to 1577 Component Component Acceptance CQC11-471543-2012 DIN V VDE V 0884-10 (VDE V 0884-10):2006-122 Recognition Notice 5A Program1 Single/Basic Insulation, Basic insulation per Basic insulation per GB4943.1- Reinforced insulation, 560 V peak 2500 V rms Isolation CSA 60950-1-03 and IEC 2011 400 V rms (588 V peak) Voltage 60950-1, 400 V rms maximum working voltage, (565 V peak) maximum tropical climate, altitude ≤ working voltage 5000 meters File E214100 File 205078 File CQC14001117247 File 2471900-4880-0001 1 In accordance with UL 1577, each ADuM1100 is proof tested by applying an insulation test voltage ≥3000 V rms for 1 sec (current leakage detection limit = 5 µA). 2 In accordance with DIN V VDE V 0884-10, each ADuM1100 is proof tested by applying an insulation test voltage ≥1050 V peak for 1 sec (partial discharge detection limit = 5 pC). The * marking branded on the component designates DIN V VDE V 0884-10 approval.
INSULATION AND SAFETY-RELATED SPECIFICATIONS Table 6. Parameter Symbol Value Unit Conditions
Minimum External Air Gap (Clearance) L(I01) 4.90 min mm Measured from input terminals to output terminals, shortest distance through air Minimum External Tracking (Creepage) L(I02) 4.01 min mm Measured from input terminals to output terminals, shortest distance path along body Minimum Internal Gap (Internal Clearance) 0.016 min mm Insulation distance through insulation Tracking Resistance (Comparative Tracking Index) CTI >400 V DIN IEC 112/VDE 0303 Part 1 Isolation Group II Material Group (DIN VDE 0110, 1/89, Table I) Maximum Working Voltage Compatible with VIORM 565 V peak Continuous peak voltage across the isolation barrier 50 Years Service Life Rev. K | Page 10 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS—5 V OPERATION ELECTRICAL SPECIFICATIONS—3.3 V OPERATION ELECTRICAL SPECIFICATIONS—MIXED 5 V/3 V OR 3 V/5 V OPERATION PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATION INFORMATION PC BOARD LAYOUT PROPAGATION DELAY-RELATED PARAMETERS METHOD OF OPERATION, DC CORRECTNESS, AND MAGNETIC FIELD IMMUNITY POWER CONSUMPTION OUTLINE DIMENSIONS ORDERING GUIDE
