Datasheet G2RL (Omron) - 6
Manufacturer | Omron |
Description | Low profile power relay with 15.7 mm height |
Pages / Page | 8 / 6 — PCB Power Relay. G2RL-1-E(-ASI, -HA, -PW1) G2RL-14-E. PCB Mounting Holes. … |
File Format / Size | PDF / 1.6 Mb |
PCB Power Relay. G2RL-1-E(-ASI, -HA, -PW1) G2RL-14-E. PCB Mounting Holes. Terminal Arrangement/. Internal Connections
G2RL
PCB Power Relay G2RL-1-E(-ASI, -HA, -PW1) G2RL-14-E PCB Mounting Holes Terminal Arrangement/
(Bottom View)
5 5 (Bottom View) Eight, 1.3-dia. holes 12.7 max. 29 max. (12.5)* (2.5) 1 2 3 4 (28.8)* 7.5 15.7 max. (15.5)* 8 7 6 5 (2.3) 20 (No coil polarity) 3.5 0.5 0.5 0.8 0.5 0.5 * Average value
G2RL-2A(-HA, -PW1), G2RL-2A4 PCB Mounting Holes Terminal Arrangement/
(Bottom View)
5 (Bottom View) 12.7 max. Six, 1.3-dia. holes 29 max. (12.5)* (2.5) 1 3 4 (28.8)* 7.5 15.7 max. (15.5)* 8 6 5 (2.3) 20 (No coil polarity) 3.5 0.5 0.5 0.8 0.5 * Average value
G2RL-2(-HA, -PW1), G2RL-24,
G
2
G2RL-2-ASI PCB Mounting Holes
(Bottom View)
R 5 5 (Bottom View) L Eight, 1.3-dia. holes 12.7 max. 29 max. (12.5)* (2.5) 1 2 3 4 (28.8)* 7.5 15.7 max. (15.5)* 8 7 6 5 (2.3) 20 (No coil polarity) 3.5 0.5 0.5 0.8 0.5 0.5 * Average value ■
Approved Standards
• The approval rating values for overseas standards are different from the performance values determined individually. Confirm the values before use.
UL Recognized:
(File No. 41643)
CSA Certified:
(File No. LR31928) Number of test Model Contact form Coil ratings Contact ratings operations G2RL-1A(-PW1) SPST-NO (1a) 12 A, 250 VAC (General Use) 40°C 100,000 3 to 48 VDC G2RL-1(-HA, -PW1) SPDT (1c) 12 A, 24 VDC (Resistive) 40°C 50,000 G2RL-1A-E(-HA, -PW1) SPST-NO (1a) 16 A, 250 VAC (General Use) 40°C 100,000 3 to 48 VDC G2RL-1-E(-HA, -PW1) SPDT (1c) 16 A, 24 VDC (Resistive) 40°C 50,000 G2RL-1A-E-ASI SPST-NO (1a) 16 A, 250 VAC (Resistive) 85°C 30,000 3 to 48 VDC G2RL-1-E-ASI SPDT (1c) TV-3 40°C 25,000 G2RL-1A-E-CV(-HA) SPST-NO (1a) 3 to 48 VDC 16 A, 250 VAC (Resistive) 105°C 100,000 G2RL-1A-H SPST-NO (1a) 10 A, 250 VAC (General Use) 40°C 3 to 48 VDC 50,000 G2RL-1-H SPDT (1c) 10 A, 24 VDC (Resistive) 40°C G2RL-2A(-HA, -PW1) DPST-NO (2a) 8 A, 277 VAC (General Use) 40°C 3 to 48 VDC 100,000 G2RL-2(-HA, -PW1) DPDT (2c) 8 A, 30 VDC (Resistive) 40°C 8 A, 250 VAC (Resistive) 85°C 15,000 G2RL-2-ASI DPDT (2c) 3 to 48 VDC 8 A, 30 VDC (Resistive) 85°C 15,000
6
