Datasheet G2RL (Omron) - 7
ManufacturerOmron
DescriptionLow profile power relay with 15.7 mm height
Pages / Page8 / 7 — PCB Power Relay. EN/IEC, VDE Certified. CQC Certified
PCB Power Relay EN/IEC, VDE Certified CQC Certified
G2RL
G2RL
(Certificate No. 119650) Number of test Model Contact form Coil ratings Contact ratings operations 12 A, 250 VAC (cosφ=1) 85°C 100,000 G2RL-1A(-PW1) SPST-NO (1a) 5, 12, 24, 48 12 A, 24 VDC (L/R=0 ms) 85°C G2RL-1(-HA, -PW1) SPDT (1c) VDC AC15: 3 A at 240 VAC at room temperature 6,000 DC13: 2.5 A at 24 VDC, 50ms at room temperature 16 A, 250 VAC (cosφ=1) 85°C 30,000 16 A, 24 VDC (L/R=0 ms) 85°C 15,000 G2RL-1A-E(-HA, -PW1) SPST-NO (1a) 5, 12, 24, 48 G2RL-1-E(-HA, -PW1) SPDT (1c) VDC AC15: 3 A at 240 VAC (NO) at room temperature, 1.5 A at 240V AC (NC) at room temperature 6,000 DC13: 2.5 A at 24 VDC (NO), 50ms at room temperature G2RL-1A-E-ASI SPST-NO (1a) 5, 12, 24, 48 16 A, 250 VAC (cos G2RL-1-E-ASI SPDT (1c) VDC φ=1) 85°C 30,000 5, 12, 24, 48 G2RL-1A-E-CV(-HA) SPST-NO (1a) 16 A, 250 VAC (cos VDC φ=1) 105°C 100,000 10 A, 250 VAC (cosφ=1) 85°C 50,000 G2RL-1A-H SPST-NO (1a) 5, 12, 24 VDC 10 A, 250 VAC (cos G2RL-1-H SPDT (1c) φ=1) 40°C 100,000 10 A, 24 VDC (L/R=0 ms) 85°C 50,000 8 A, 250 VAC (cosφ=1) 85°C 30,000 G2RL-2A (-HA, -PW1) DPST-NO (2a) 5, 12, 24, 48 8 A, 30 VDC (L/R=0 ms) 85°C 15,000 VDC AC15: 1.5 A at 240VAC at room temperature G2RL-2 (-HA, -PW1) DPDT (2c) 6,000 DC13: 2 A at 30 VDC, 50ms at room temperature 5, 12, 24, 48 8 A, 250V AC (Resistive) 85°C 15,000 G2RL-2-ASI DPDT (2c) VDC 8 A, 30V DC (Resistive) 85°C 15,000
CQC Certified
(Certificate No. CQC17002171904) Number of test Model Contact form Coil ratings Contact ratings operations G 12 A, 250 VAC (cosφ=1) at room temperature 50,000 G2RL-1A(-PW1) SPST-NO (1a) 2 12 A, 24 VDC (L/R=0 ms) at room temperature 30,000 5 to 48 VDC R 12 A, 250 VAC (cosφ=1) at room temperature 50,000 G2RL-1(-HA, -PW1) SPDT (1c) L 12 A, 24 VDC (L/R=0 ms) at room temperature 30,000 G2RL-1A-E(-ASI, -HA, -PW1) 16 A, 250 VAC (cosφ=1) at room temperature 30,000 SPST-NO (1a) G2RL-1A-E-CV(-HA) 16 A, 24 VDC (L/R=0 ms) at room temperature 30,000 5 to 48 VDC 16 A, 250 VAC (cosφ=1) at room temperature 30,000 G2RL-1-E(-ASI,-HA, -PW1) SPDT (1c) 16 A, 24 VDC (L/R=0 ms) at room temperature 30,000 8 A, 250 VAC (cosφ=1) at room temperature 30,000 G2RL-2A (4)(-HA, -PW1) DPST-NO (2a) 8 A, 30 VDC (L/R=0 ms) at room temperature 30,000 5 to 48 VDC 3 A, 250 VAC (cosφ=1) at room temperature 30,000 G2RL-2(-ASI,-HA, -PW1) DPDT (2c) 3 A, 30 VDC (L/R=0 ms) at room temperature 30,000 Creepage distance 8 mm min. Clearance distance 8 mm min. Insulation material group IIIa Type of insulation coil-contact circuit Reinforced open contact circuit Micro disconnection Rated Insulation voltage 250 V Pollution degree 3 (Flux protection / Sealed) Rated voltage system 250 V / 400 V (Flux protection) Over voltage category III Category of protection according to IEC 61810-1 RT II (Flux protection) / RT III (Sealed) <HA Models only> Glow wire according to IEC 60335-1 GWT 750°C min. (IEC 60695-2-11) / GWFI 850°C min. (IEC 60695-2-12) Tracking Index of relay base PTI 250 V min. (housing parts)
7
