Datasheet MAX4100, MAX4101 (Maxim) - 4
ManufacturerMaxim
Description500MHz, Low-Power Op Amps
Pages / Page12 / 4 — 500MHz, Low-Power Op Amps. ____________________________Typical Operating …
File Format / SizePDF / 148 Kb
500MHz, Low-Power Op Amps. ____________________________Typical Operating Characteristics (continued). MAX4100
500MHz, Low-Power Op Amps ____________________________Typical Operating Characteristics (continued) MAX4100
(VCC = 5V, VEE = -5V, TA = +25°C, unless otherwise noted.)
MAX4100 MAX4100 LARGE-SIGNAL PULSE RESPONSE MAX4100 SMALL-SIGNAL PULSE RESPONSE (AVCL = +5) OUTPUT RESISTANCE vs. FREQUENCY (AVCL = +1)
100 MAX4100-04 IN GND MAX4100-05 MAX4100-06 10 ) IN GND Ω 1.0 RESISTANCE ( OUT GND VOLTAGE (500mV/div) VOLTAGE (20mV/div) 0.1 OUT GND
MAX4100/MAX4101
0.01 10k 100k 1M 10M 100M 1G TIME (20ns/div) TIME (10ns/div) FREQUENCY (Hz)
MAX4100 MAX4101 SMALL-SIGNAL PULSE RESPONSE MAX4101 LARGE-SIGNAL PULSE RESPONSE (AVCL = +5) OUTPUT RESISTANCE vs. FREQUENCY (AVCL = +2)
100 MAX4100-07 IN GND MAX4100-08 MAX4100-09 IN GND 10 ) Ω 1.0 OUT GND RESISTANCE ( VOLTAGE (10mV/div) VOLTAGE (500mV/div) OUT GND 0.1 0.01 10k 100k 1M 10M 100M 1G TIME (50ns/div) TIME (10ns/div) FREQUENCY (Hz)
MAX4101 MAX4101 MAX4101 LARGE-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE (AVCL = +10) (AVCL = +2) (AVCL = +10)
MAX4100-11a MAX4100-10 IN GND MAX4100-11b IN IN OUT GND OUT GND VOLTAGE (500mV/div) OUT GND VOLTAGE (10mV/div) VOLTAGE (10mV/div) TIME (20ns/div) TIME (10ns/div) TIME (50ns/div)
4 _______________________________________________________________________________________
