Datasheet MAX4100, MAX4101 (Maxim) - 5
Manufacturer | Maxim |
Description | 500MHz, Low-Power Op Amps |
Pages / Page | 12 / 5 — 500MHz, Low-Power Op Amps. MAX4100/MAX4101. … |
File Format / Size | PDF / 148 Kb |
500MHz, Low-Power Op Amps. MAX4100/MAX4101. ____________________________Typical Operating Characteristics (continued)
500MHz, Low-Power Op Amps MAX4100/MAX4101 ____________________________Typical Operating Characteristics (continued)
(VCC = 5V, VEE = -5V, TA = +25°C, unless otherwise noted.)
INPUT OFFSET VOLTAGE INPUT BIAS CURRENT INPUT OFFSET CURRENT vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
1.0 7 0.35 0.5 6 0.25 MAX4100 TOC-12 MAX4100 TOC-14A MAX4100 TOC-14B 0 5 0.15 -0.5 µA) µA) 4 0.05 -1.0 3 -0.05 VOLTAGE (mV) -1.5 CURRENT ( CURRENT ( 2 -0.15 -2.0 1 -0.25 -2.5 -3.0 0 -0.35 -75 -50 -25 0 25 50 75 100 125 -75 -50 -25 0 25 50 75 100 125 -75 -50 -25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
MAX4100 MAX4100 POWER-SUPPLY CURRENT COMMON-MODE REJECTION POWER-SUPPLY REJECTION vs. TEMPERATURE vs. FREQUENCY vs. FREQUENCY
7 90 80 80 70 MAX4100 TOC-13 MAX4100 TOC-15 MAX4100 TOC-16 70 6 60 60 50 50 5 40 CMR (dB) 40 PSR (dB) PSR- CURRENT (mA) 30 30 4 20 20 PSR+ 10 10 3 0 0 -75 -50 -25 0 25 50 75 100 125 30k 100k 1M 10M 100M 1G 0.1M 1M 10M 100M 1G TEMPERATURE (°C) FREQUENCY (Hz) FREQUENCY (Hz)
POSITIVE OUTPUT SWING OUTPUT SWING vs. TEMPERATURE vs. LOAD RESISTANCE
6 3.5 5 R MAX4100-17 L = ∞ 3.0 MAX4100 TOC-20A 4 3 2.5 RL = 100Ω 2 2.0 -2 1.5 RL = 100Ω -3 1.0 OUTPUT SWING (Vp-p) POSITIVE OUTPUT SWING (V) -4 -5 RL = ∞ 0.5 -6 0 -75 -50 -25 0 25 50 75 100 125 10 22 33 50 75 TEMPERATURE (°C) LOAD RESISTANCE (Ω)
_______________________________________________________________________________________ 5
