Datasheet ADG5212, ADG5213 (Analog Devices) - 6
DescriptionHigh Voltage Latch-Up Proof, Quad SPST Switches
Pages / Page20 / 6 — ADG5212/ADG5213. Data Sheet. Parameter. 25°C. −40°C to +85°C. −40°C to …
File Format / SizePDF / 438 Kb
ADG5212/ADG5213. Data Sheet. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments. 36 V SINGLE SUPPLY
ADG5212/ADG5213 Data Sheet Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments 36 V SINGLE SUPPLY
link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 15 link to page 14 link to page 14 link to page 7
Insertion Loss −11 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 28 CS (Off) 3.5 pF typ VS = 6 V, f = 1 MHz CD (Off) 5.5 pF typ VS = 6 V, f = 1 MHz CD (On), CS (On) 9 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 40 µA typ Digital inputs = 0 V or VDD 65 µA max VDD 9/40 V min/V max GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test.
36 V SINGLE SUPPLY
VDD = 36 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 4. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V max On Resistance, RON 150 Ω typ VS = 0 V to 30 V, IS = −1 mA, see Figure 24 170 215 245 Ω max VDD = 32.4 V, VSS = 0 V On-Resistance Match Between Channels, ∆RON 1.6 Ω typ VS = 0 V to 30 V, IS = −1 mA 8 9 10 Ω max On-Resistance Flatness, RFLAT(ON) 35 Ω typ VS = 0 V to 30 V, IS = −1 mA 50 60 65 Ω max LEAKAGE CURRENTS VDD =39.6 V, VSS = 0 V Source Off Leakage, IS (Off) 0.01 nA typ VS = 1 V/30 V, VD = 30 V/1 V, see Figure 23 0.1 0.2 0.4 nA max Drain Off Leakage, ID (Off) 0.01 nA typ VS = 1 V/30 V, VD = 30 V/1 V, see Figure 23 0.1 0.2 0.4 nA max Channel On Leakage, ID (On), IS (On) 0.02 nA typ VS = VD = 1 V/30 V, see Figure 26 0.2 0.25 0.9 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS1 tON 190 ns typ RL = 300 Ω, CL = 35 pF 230 255 265 ns max VS = 18 V, see Figure 30 tOFF 175 ns typ RL = 300 Ω, CL = 35 pF 215 230 245 ns max VS = 18 V, see Figure 30 Break-Before-Make Time Delay, tD 45 ns typ RL = 300 Ω, CL = 35 pF (ADG5213 Only) 25 ns min VS1 = VS2 = 18 V, see Figure 29 Charge Injection, QINJ −0.5 pC typ VS = 18 V, RS = 0 Ω, CL = 1 nF, see Figure 31 Off Isolation −80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 25 Channel-to-Channel Crosstalk −105 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, Figure 27 Rev. A | Page 6 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
