Datasheet ADG5408, ADG5409 (Analog Devices) - 6
DescriptionHigh Voltage Latch-Up Proof, 4-/8-Channel Multiplexers
Pages / Page24 / 6 — ADG5408/ADG5409. Data Sheet. Parameter. 25°C. −40°C to +85°C −40°C to …
RevisionC
File Format / SizePDF / 413 Kb
ADG5408/ADG5409. Data Sheet. Parameter. 25°C. −40°C to +85°C −40°C to +125°C Unit. Test Conditions/Comments. 36 V SINGLE SUPPLY
ADG5408/ADG5409 Data Sheet Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments 36 V SINGLE SUPPLY
link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 6
DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 230 ns typ RL = 300 Ω, CL = 35 pF 321 388 430 ns max VS = 8 V; see Figure 32 tON (EN) 215 ns typ RL = 300 Ω, CL = 35 pF 276 345 397 ns max VS = 8 V; see Figure 34 tOFF (EN) 134 ns typ RL = 300 Ω, CL = 35 pF 161 187 209 ns max VS = 8 V; see Figure 34 Break-Before-Make Time Delay, tD 118 ns typ RL = 300 Ω, CL = 35 pF 55 ns min VS1 = VS2 = 8 V; see Figure 33 Charge Injection, QINJ 45 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 35 Off Isolation −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 Channel-to-Channel Crosstalk −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 27 Total Harmonic Distortion + Noise 0.1 % typ RL = 1 kΩ, 6 V p-p, f = 20 Hz to 20 kHz; see Figure 30 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 31 ADG5408 35 MHz typ ADG5409 74 MHz typ Insertion Loss −1.8 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 31 CS (Off) 22 pF typ VS = 6 V, f = 1 MHz CD (Off) ADG5408 119 pF typ VS = 6 V, f = 1 MHz ADG5409 59 pF typ VS = 6 V, f = 1 MHz CD (On), CS (On) ADG5408 146 pF typ VS = 6 V, f = 1 MHz ADG5409 86 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 40 µA typ Digital inputs = 0 V or VDD 50 65 µA max VDD 9/40 V min/V max GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test.
36 V SINGLE SUPPLY
VDD = 36 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 4. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 14.5 Ω typ VS = 0 V to 30 V, IS = −10 mA; see Figure 26 16 19 23 Ω max VDD = 32.4 V, VSS = 0 V On-Resistance Match Between 0.3 Ω typ VS = 0 V to 30 V, IS = −10 mA Channels, ∆RON 0.8 1.3 1.4 Ω max On-Resistance Flatness, RFLAT (ON) 3.5 Ω typ VS = 0 V to 30 V, IS = −10 mA 4.3 5.5 6.5 Ω max LEAKAGE CURRENTS VDD =39.6 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = 1 V/30 V, VD = 30 V/1 V; see Figure 29 ±0.25 ±1 ±7 nA max Rev. C | Page 6 of 24 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or D Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
