Datasheet ADG5408, ADG5409 (Analog Devices)
Description | High Voltage Latch-Up Proof, 4-/8-Channel Multiplexers |
Pages / Page | 24 / 1 — High Voltage Latch-Up Proof,. 4-/8-Channel Multiplexers. Data Sheet. … |
Revision | C |
File Format / Size | PDF / 413 Kb |
High Voltage Latch-Up Proof,. 4-/8-Channel Multiplexers. Data Sheet. ADG5408/. ADG5409. FEATURES. FUNCTIONAL BLOCK DIAGRAMS
High Voltage Latch-Up Proof, 4-/8-Channel Multiplexers Data Sheet ADG5408/ ADG5409 FEATURES FUNCTIONAL BLOCK DIAGRAMS Latch-up proof ADG5408 ADG5409 8 kV human body model (HBM) ESD rating S1 S1A Low on resistance (13.5 Ω) DA ±9 V to ±22 V dual-supply operation S4A 9 V to 40 V single-supply operation D 48 V supply maximum ratings Fully specified at ±15 V, ±20 V, +12 V, and +36 V S1B DB VSS to VDD analog signal range S8 S4B APPLICATIONS 1-OF-8 1-OF-4 DECODER DECODER Relay replacement Automatic test equipment
001
Data acquisition A0 A1 A2 EN A0 A1 EN
09206-
Instrumentation
Figure 1.
Avionics Audio and video switching Communication systems GENERAL DESCRIPTION
The ADG5408/ADG5409 are monolithic CMOS analog multi- The ADG5408/ADG5409 do not have VL pins; rather, the logic plexers comprising eight single channels and four differential power supply is generated internal y by an on-chip voltage channels, respectively. The ADG5408 switches one of eight generator. inputs to a common output, as determined by the 3-bit binary
PRODUCT HIGHLIGHTS
address lines, A0, A1, and A2. The ADG5409 switches one of four differential inputs to a common differential output, as 1. Trench isolation guards against latch-up. A dielectric trench determined by the 2-bit binary address lines, A0 and A1. separates the P and N channel transistors thereby preventing latch-up even under severe overvoltage conditions. An EN input on both devices enables or disables the device. 2. Low RON. When EN is disabled, all channels switch off. The on-resistance 3. Dual-supply operation. For applications where the analog profile is very flat over the full analog input range, which ensures signal is bipolar, the ADG5408/ADG5409 can be operated good linearity and low distortion when switching audio signals. from dual supplies up to ±22 V. High switching speed also makes the parts suitable for video 4. Single-supply operation. For applications where the analog signal switching. signal is unipolar, the ADG5408/ADG5409 can be operated Each switch conducts equally wel in both directions when on, from a single rail power supply up to 40 V. and each switch has an input signal range that extends to the 5. 3 V logic compatible digital inputs: VINH = 2.0 V, VINL = 0.8 V. power supplies. In the off condition, signal levels up to the 6. No VL logic power supply required. supplies are blocked.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2010–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or D Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
