Datasheet ADG5408-EP, ADG5409-EP (Analog Devices) - 3
DescriptionHigh Voltage Latch-Up Proof, 4-/8-Channel Multiplexers
Pages / Page18 / 3 — Enhanced Product. ADG5408-EP/ADG5409-EP. SPECIFICATIONS ±15 V DUAL …
File Format / SizePDF / 340 Kb
Enhanced Product. ADG5408-EP/ADG5409-EP. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. Parameter. 25°C. −40°C to +85°C
Enhanced Product ADG5408-EP/ADG5409-EP SPECIFICATIONS ±15 V DUAL SUPPLY Table 1 Parameter 25°C −40°C to +85°C
link to page 16 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 4
VDD = +15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. Parameter 25°C −40°C to +85°C −55°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 13.5 Ω typ VS = ±10 V, IS = −10 mA; see Figure 24 15 18 22 Ω max VDD = +13.5 V, VSS = −13.5 V On-Resistance Match Between 0.3 Ω typ VS = ±10 V, IS = −10 mA Channels, ∆RON 0.8 1.3 1.4 Ω max On-Resistance Flatness, RFLAT (ON) 1.8 Ω typ VS = ±10 V, IS = −10 mA 2.2 2.6 3 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off ) ±0.05 nA typ VS = ±10 V, VD = 10 V; see Figure 27 ±0.25 ±1 ±7 nA max Drain Off Leakage, ID (Off ) ±0.1 nA typ VS = ±10 V, VD = 10 V; see Figure 27 ±0.4 ±4 ±30 nA max Channel On Leakage, ID (On), IS (On) ±0.1 nA typ VS = VD = ±10 V; see Figure 23 ±0.4 ±4 ±30 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 170 ns typ RL = 300 Ω, CL = 35 pF 217 258 292 ns max VS = 10 V; see Figure 30 tON (EN) 140 ns typ RL = 300 Ω, CL = 35 pF 175 213 242 ns max VS = 10 V; see Figure 32 tOFF (EN) 130 ns typ RL = 300 Ω, CL = 35 pF 161 183 198 ns max VS = 10 V; see Figure 32 Break-Before-Make Time Delay, tD 50 ns typ RL = 300 Ω, CL = 35 pF 13 ns min VS1 = VS2 = 10 V; see Figure 31 Charge Injection, QINJ 115 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 33 Off Isolation −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 26 Channel-to-Channel Crosstalk −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 25 Total Harmonic Distortion + Noise 0.01 % typ RL = 1 kΩ, 15 V p-p, f = 20 Hz to 20 kHz; see Figure 28 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 29 ADG5408-EP 50 MHz typ ADG5409-EP 87 MHz typ Insertion Loss 0.9 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Figure 29 CS (Off ) 15 pF typ VS = 0 V, f = 1 MHz CD (Off ) ADG5408-EP 102 pF typ VS = 0 V, f = 1 MHz ADG5409-EP 50 pF typ VS = 0 V, f = 1 MHz Rev. 0 | Page 3 of 18 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
