Datasheet ADG1401, ADG1402 (Analog Devices) - 8
Description1 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS SPST Switches
Pages / Page16 / 8 — ADG1401/ADG1402. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. S 1. 8 D. …
File Format / SizePDF / 451 Kb
ADG1401/ADG1402. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. S 1. 8 D. ADG1401/. NC 2. ADG1402. 7 VSS. TOP VIEW. GND 3. 6 IN. (Not to Scale)
ADG1401/ADG1402 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS S 1 8 D ADG1401/ NC 2 ADG1402 7 VSS TOP VIEW GND 3 6 IN (Not to Scale)
ADG1401/ADG1402 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS S 1 8 D ADG1401/ NC 2 ADG1402 7 VSS TOP VIEW GND 3 6 IN (Not to Scale) V 4 DD 5 NC NOTES
3
1. EXPOSED PAD TIED TO SUBSTRATE, V
00
SS.
6-
2. NC = NO CONNECT.
48 08 Figure 3. ADG1401/ADG1402 Pin Configuration
Table 7. ADG1401/ADG1402 Pin Function Descriptions Pin No. Mnemonic Description
1 S Source Terminal. This pin can be an input or output. 2 NC No Connect. 3 GND Ground (0 V) Reference. 4 VDD Most Positive Power Supply Potential. 5 NC No Connect. 6 IN Logic Control Input. 7 VSS Most Negative Power Supply Potential. 8 D Drain Terminal. This pin can be an input or output. EPAD Exposed pad tied to substrate, VSS, for LFCSP package.
Table 8. ADG1401/ADG1402 Truth Table ADG1401 IN ADG1402 IN Switch Condition
1 0 On 0 1 Off Rev. 0 | Page 8 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
