Datasheet ADG1401, ADG1402 (Analog Devices) - 10
Description | 1 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS SPST Switches |
Pages / Page | 16 / 10 — ADG1401/ADG1402. VDD = +15V. IDD PER CHANNEL. VSS = –15V. A = 25°C. VBIAS … |
File Format / Size | PDF / 451 Kb |
ADG1401/ADG1402. VDD = +15V. IDD PER CHANNEL. VSS = –15V. A = 25°C. VBIAS = ±10V. A) µ. URRE. IS (OFF) – +. DD = +15V. D (OFF) + –. DD = 12V
ADG1401/ADG1402 80 90 VDD = +15V IDD PER CHANNEL VSS = –15V T 70 80 A = 25°C VBIAS = ±10V 70 60 A) 60 (n 50 NT 50 40 A) µ URRE IS (OFF) – + ( 40 V C I DD = +15V V 30 D (OFF) + – DD = 12V E V I I DD SS = –15V S (OFF) – + VSS = 0V I 30 D (OFF) + – 20 I AKAG D, IS (ON) + + E I 20 D, IS (ON) – – L 10 10 VDD = +5V VSS = –5V 0 0 –10
28
–10
8 0
0 20 40 60 80 100 120
6-
0 2 4 6 8 10 12 14
01 6- 48 48 08
TEMPERATURE (°C) LOGIC LEVEL, IN (V)
08 Figure 10. Leakage Currents as a Function of Temperature, Figure 13. IDD vs. Logic Level ±15 V Dual Supply
70 1000 VDD = 12V T V A = 25°C SS = 0V V 60 V 800 DD = +5V BIAS = 1V/10V VSS = –5V 600 ) 50 A C) 400 (n p NT 40 N ( 200 V IO DD = +12V I VSS = 0V S (OFF) + – T C URRE 30 ID (OFF) – + 0 JE VDD = +15V C IS (OFF) – + N V E I I SS = –15V D (OFF) + – E –200 20 ID, IS (ON) + + I AKAG D, IS (ON) – – E –400 HARG L 10 C –600 0 –800 –10 –1000
9
30
–15 –10 –5 0 5 10 15
0 -02 6- 86
TEMPERATURE (°C)
48 84
V
0
S (V)
08 Figure 11. Leakage Currents as a Function of Temperature, Figure 14. Charge Injection vs. Source Voltage +12 V Single Supply
60 V 350 DD = +5V VSS = –5V 50 VBIAS = ±4.5V 300 ) A 40 n ( 250 NT tOFF (±5V) 30 I ) S (OFF) + – s 200 I n D (OFF) – + ( CURRE IS (OFF) – + E E 20 I M G D (OFF) + – 150 t I TI ON (±5V) D, IS (ON) + + I AKA D, IS (ON) – – E 10 L 100 t 0 ON (12V) 50 tOFF (12V) tOFF (±15V) t –10 ON (±15V)
27 0
0 20 40 60 80 100 120 0
6-
–40 –20 0 20 40 60 80 100 120
09 48 0 6- 08
TEMPERATURE (°C) TEMPERATURE (°C)
48 08 Figure 12. Leakage Currents as a Function of Temperature, Figure 15. tON/tOFF Times vs. Temperature ±5 V Dual Supply Rev. 0 | Page 10 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
