Datasheet ADG1414 (Analog Devices) - 9
Description9.5 Ω RON ±15 V/+12 V/±5 V iCMOS Serially-Controlled Octal SPST Switches
Pages / Page19 / 9 — Data Sheet. ADG1414. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter. …
File Format / SizePDF / 536 Kb
Data Sheet. ADG1414. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter. Rating. THERMAL RESISTANCE. Table 8. Thermal Resistance
Data Sheet ADG1414 ABSOLUTE MAXIMUM RATINGS Table 7 Parameter Rating THERMAL RESISTANCE Table 8 Thermal Resistance
link to page 7
TA = 25°C, unless otherwise noted. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
Table 7.
stress rating only; functional operation of the product at these
Parameter Rating
or any other conditions above those indicated in the operational VDD to VSS 35 V section of this specification is not implied. Operation beyond VDD to GND −0.3 V to +25 V the maximum operating conditions for extended periods may VSS to GND +0.3 V to −25 V affect product reliability. VL to GND −0.3 V to +7 V Only one absolute maximum rating may be applied at any one Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first time. Digital Inputs1 GND − 0.3 V to VL + 0.3 V or
THERMAL RESISTANCE
30 mA, whichever occurs first Continuous Current, Sx or Dx Pins Table 4 specifications + 15%
Peak Current, Sx or Dx (Pulsed at
Package Type θJA θJC Unit
1 ms, 10% Duty Cycle Maximum) 24-Lead TSSOP1 112.6 50 °C/W TSSOP Package 300 mA 24-Lead LFCSP2 30.4 °C/W LFCSP Package 400 mA 1 4-layer board. Operating Temperature Range 2 4-layer board and exposed paddle soldered to VSS. Industrial (B Version) –40°C to +125°C
ESD CAUTION
Storage Temperature Range −65°C to +150°C Junction Temperature 150°C Reflow Soldering Peak 260°C Temperature, Pb free Time at Peak Temperature 10 sec to 40 sec 1 Overvoltages at the analog and digital inputs are clamped by internal diodes. Limit the current to the maximum ratings given. Rev. B | Page 9 of 19 Document Outline Features Applications Functional Block Diagram Product Highlights Revision History Specifications ±15 V Dual Supply 12 V Single Supply ±5 V Dual Supply Continuous Current per Channel Timing Characteristics Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Theory of Operation Serial Interface Input Shift Register Power-On Reset Daisy Chaining Outline Dimensions Ordering Guide
