Datasheet ADG1606, ADG1607 (Analog Devices)
Description4.5 Ω RON, 16-Channel, Differential 8-Channel, ±5 V,+12 V,+5 V, and +3.3 V Multiplexers
Pages / Page22 / 1 — 4.5 Ω RON, 16-Channel, Differential 8-Channel,. ±5 V,+12 V,+5 V, and +3.3 …
RevisionA
File Format / SizePDF / 518 Kb
4.5 Ω RON, 16-Channel, Differential 8-Channel,. ±5 V,+12 V,+5 V, and +3.3 V Multiplexers. Data Sheet. ADG1606/. ADG1607. FEATURES
Datasheet ADG1606, ADG1607 Analog Devices, Revision: A
4.5 Ω RON, 16-Channel, Differential 8-Channel, ±5 V,+12 V,+5 V, and +3.3 V Multiplexers Data Sheet ADG1606/ ADG1607 FEATURES FUNCTIONAL BLOCK DIAGRAMS 4.5 Ω typical on resistance ADG1606 1.1 Ω on resistance flatness S1 ±3.3 V to ±8 V dual supply operation 3.3 V to 16 V single supply operation D No VL supply required 3 V logic-compatible inputs S16 Rail-to-rail operation 1-OF-16 Up to 378 mA of continuous current per channel DECODER 28-lead TSSOP and 32-lead, 5 mm × 5 mm LFCSP
001
A0 A1 A2 A3 EN
08489-
Figure 1.
Communication systems Medical systems Audio signal routing ADG1607 Video signal routing S1A DA Automatic test equipment S8A Data acquisition systems Battery-powered systems S1B DB Sample-and-hold systems S8B Relay replacements 1-OF-8 DECODER
002
A0 A1 A2 EN
08489- Figure 2.
GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG1606 and ADG1607 are monolithic iCMOS® analog 1. 7.5 Ω maximum on resistance over temperature. multiplexers comprising of 16 single channels and eight 2. Minimum distortion: THD + N = 0.04% differential channels, respectively. The ADG1606 switches one of 3. 3 V logic-compatible digital inputs: VINH = 2.0 V, VINL = 0.8 V. 16 inputs to a common output, as determined by the 4-bit 4. No VL logic power supply required. binary address lines (A0, A1, A2, and A3). The ADG1607 switches one of eight differential inputs to a common differential output, as determined by the 3-bit binary address lines (A0, A1, and A2). An EN input on both devices enables or disables the device. When disabled, all channels switch off. When enabled, each channel conducts equally wel in both directions and has an input signal range that extends to the supplies. The ultralow on resistance and on-resistance flatness of these switches make them ideal solutions for data acquisition and gain switching applications where low distortion is critical. iCMOS® construction ensures ultralow power dissipation, making the parts ideally suited for portable and battery- powered instruments.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2009–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
