Datasheet ADG1606, ADG1607 (Analog Devices) - 4
Description4.5 Ω RON, 16-Channel, Differential 8-Channel, ±5 V,+12 V,+5 V, and +3.3 V Multiplexers
Pages / Page22 / 4 — ADG1606/ADG1607. Data Sheet. 12 V SINGLE SUPPLY. Table 2. −40°C to. …
File Format / SizePDF / 518 Kb
ADG1606/ADG1607. Data Sheet. 12 V SINGLE SUPPLY. Table 2. −40°C to. Parameter. 25°C. +85°C. +125°C. Unit. Test Conditions/Comments
ADG1606/ADG1607 Data Sheet 12 V SINGLE SUPPLY Table 2 −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 18 link to page 18 link to page 17 link to page 18 link to page 19 link to page 19 link to page 19 link to page 19
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 4 Ω typ VS = 0 V to 10 V, IS = −10 mA; see Figure 26 5 6.2 7 Ω max VDD = 10.8 V, VSS = 0 V On Resistance Match Between Channels (∆RON) 0.2 Ω typ VS = 10 V, IS = −10 mA 0.5 0.8 0.9 Ω max On Resistance Flatness (RFLAT(ON)) 1 Ω typ VS = 0 V to 10 V, IS = −10 mA 1.3 1.6 1.9 Ω max LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.02 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 27 ±0.15 ±0.5 ±3 nA max Drain Off Leakage, ID (Off) ±0.05 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 27 ADG1606 ±0.2 ±3 ±25 nA max Channel On Leakage, ID, IS (On) ±0.1 nA typ VS = VD = 1 V or 10 V; see Figure 28 ±0.3 ±3 ±25 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±0.003 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 143 ns typ RL = 300 Ω, CL = 35 pF 170 198 221 ns max VS = 8 V; see Figure 29 tON (EN) 108 ns typ RL = 300 Ω, CL = 35 pF 128 136 142 ns max VS = 8 V; see Figure 31 tOFF (EN) 90 ns typ RL = 300 Ω, CL = 35 pF 109 132 150 ns max VS = 8 V; see Figure 31 Break-Before-Make Time Delay, tBBM 40 ns typ RL = 300 Ω, CL = 35 pF 15 ns min VS1 = VS2 = 8 V; see Figure 30 Charge Injection 33 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 32 Off Isolation −62 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 33 Channel-to-Channel Crosstalk −62 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 35 Total Harmonic Distortion + Noise (THD + N) 0.04 % typ RL = 110 Ω, 5 V p-p, f = 20 Hz to 20 kHz; see Figure 36 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 34 ADG1606 22 MHz typ ADG1607 38 MHz typ CS (Off) 18 pF typ VS = 6 V, f = 1 MHz CD (Off) ADG1606 240 pF typ VS = 6 V, f = 1 MHz ADG1607 120 pF typ VS = 6 V, f = 1 MHz CD, CS (On) ADG1606 263 pF typ VS = 6 V, f = 1 MHz ADG1607 143 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 12 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max ADG1606 300 µA typ Digital inputs = 5 V 480 µA max ADG1607 370 µA typ Digital inputs = 5 V 600 µA max VDD 3.3/16 V min/max 1 Guaranteed by design, not subject to production test. Rev. A | Page 4 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
