Datasheet ADG1606, ADG1607 (Analog Devices) - 5
Description4.5 Ω RON, 16-Channel, Differential 8-Channel, ±5 V,+12 V,+5 V, and +3.3 V Multiplexers
Pages / Page22 / 5 — Data Sheet. ADG1606/ADG1607. 5 V SINGLE SUPPLY. Table 3. −40°C to. …
File Format / SizePDF / 518 Kb
Data Sheet. ADG1606/ADG1607. 5 V SINGLE SUPPLY. Table 3. −40°C to. Parameter. 25°C. +85°C. +125°C. Unit. Test Conditions/Comments
Data Sheet ADG1606/ADG1607 5 V SINGLE SUPPLY Table 3 −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 18 link to page 18 link to page 17 link to page 18 link to page 19 link to page 19 link to page 19 link to page 19
VDD = 5 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 8.5 Ω typ VS = 0 V to 4.5 V, IS = −10 mA; see Figure 26 9.5 11.5 12.5 Ω max VDD = 4.5 V, VSS = 0 V On Resistance Match Between Channels (∆RON) 0.3 Ω typ VS = 0 V to 4.5 V, IS = −10 mA 0.8 1.1 1.2 Ω max On Resistance Flatness (RFLAT(ON)) 1.8 Ω typ VS = 0 V to 4.5 V, IS = −10 mA 2.4 2.7 3 Ω max LEAKAGE CURRENTS VDD = 5.5 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.01 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 27 ±0.15 ±0.5 ±3 nA max Drain Off Leakage, ID (Off) ±0.02 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 27 ADG1606 ±0.2 ±3 ±25 nA max Channel On Leakage, ID, IS (On) ±0.05 nA typ VS = VD = 1 V or 4.5 V; see Figure 28 ±0.3 ±3 ±25 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±0.003 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 220 ns typ RL = 300 Ω, CL = 35 pF 280 324 360 ns max VS = 2.5 V; see Figure 29 tON (EN) 160 ns typ RL = 300 Ω, CL = 35 pF 202 221 234 ns max VS = 2.5 V; see Figure 31 tOFF (EN) 154 ns typ RL = 300 Ω, CL = 35 pF 197 232 259 ns max VS = 2.5 V; see Figure 31 Break-Before-Make Time Delay, tBBM 45 ns typ RL = 300 Ω, CL = 35 pF 15 ns min VS1 = VS2 = 2.5 V; see Figure 30 Charge Injection 12 pC typ VS = 2.5 V, RS = 0 Ω, CL = 1 nF; see Figure 32 Off Isolation −62 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 33 Channel-to-Channel Crosstalk −62 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 35 Total Harmonic Distortion + Noise (THD + N) 0.35 % typ RL = 110 Ω, f = 20 Hz to 20 kHz, VS = 3.5 V p-p; see Figure 36 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 34 ADG1606 19 MHz typ ADG1607 34 MHz typ CS (Off) 20 pF typ VS = 2.5 V, f = 1 MHz CD (Off) ADG1606 270 pF typ VS = 2.5 V, f = 1 MHz ADG1607 137 pF typ VS = 2.5 V, f = 1 MHz CD, CS (On) ADG1606 300 pF typ VS = 2.5 V, f = 1 MHz ADG1607 160 pF typ VS = 2.5 V, f = 1 MHz POWER REQUIREMENTS VDD = 5.5 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max VDD 3.3/16 V min/max 1 Guaranteed by design, not subject to production test. Rev. A | Page 5 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
