link to page 7 ADG1606/ADG1607Data SheetABSOLUTE MAXIMUM RATINGS T THERMAL RESISTANCE A = 25°C, unless otherwise noted. θ Table 7. JA is specified for the worst-case conditions, that is, a device soldered in a circuit board for surface-mount packages. ParameterRating VDD to VSS 18 V Table 8. Thermal Resistance VDD to GND −0.3 V to +18 V Package TypeθJAθJCUnit VSS to GND +0.3 V to −18 V 28-Lead TSSOP 97.9 14 °C/W Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or 32-Lead LFCSP 46 °C/W 30 mA, whichever occurs first Digital Inputs2 GND − 0.3 V to VDD + 0.3 V or ESD CAUTION 30 mA, whichever occurs first Peak Current, S or D 1.1 A (pulsed at 1 ms, 10% duty cycle maximum) Continuous Current, S or D3 Data + 15% Operating Temperature Range Industrial (B Version) −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C Reflow Soldering Peak 260°C Temperature, Pb Free 1 Overvoltages at IN, S, or D are clamped by internal diodes. Current should be limited to the maximum ratings given. 2 Overvoltages at the Ax, EN, Sx, or Dx pins are clamped by internal diodes. Current should be limited to the maximum ratings given. 3 See Table 5. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Only one absolute maximum rating may be applied at any one time. Rev. A | Page 8 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
