Data SheetADG1606/ADG1607PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONSV128DDDDDSSNCVNCDNCNCNCVNC227VSS3231302928272625NC326S8S16425S7S16 124 S8S15 223 S7S15524S6ADG1606S14 322 S6S146TOP VIEW23S5ADG1606S13 421 S5(Not to Scale)TOP VIEWS13722S4S12 520 S4(Not to Scale)619S12S11S3821S3S10 718 S2S11920S2S9 817 S1S10 1019S191S9 1118EN1011213141516GND 1217A0NDA3A2NCNCA1A0ENGNC 1316A1A3 1415A2NOTES 003 1. NC = NO CONNECT. 004 NC = NO CONNECT2. EXPOSED PAD TIED TO SUBSTRATE, V 08489- SS. 08489- Figure 3. ADG1606 TSSOP Pin Configuration Figure 4. ADG1606 LFCSP Pin Configuration Table 9. ADG1606 Pin Function DescriptionsPin No.TSSOPLFCSPMnemonicDescription 1 31 VDD Most Positive Power Supply Potential. 2, 3, 13 12, 13, 26, NC No Connect. 27, 28, 30, 32 4 1 S16 Source Terminal 16. This pin can be an input or an output. 5 2 S15 Source Terminal 15. This pin can be an input or an output. 6 3 S14 Source Terminal 14. This pin can be an input or an output. 7 4 S13 Source Terminal 13. This pin can be an input or an output. 8 5 S12 Source Terminal 12. This pin can be an input or an output. 9 6 S11 Source Terminal 11. This pin can be an input or an output. 10 7 S10 Source Terminal 10. This pin can be an input or an output. 11 8 S9 Source Terminal 9. This pin can be an input or an output. 12 9 GND Ground (0 V) Reference. 14 10 A3 Logic Control Input. 15 11 A2 Logic Control Input. 16 14 A1 Logic Control Input. 17 15 A0 Logic Control Input. 18 16 EN Active High Digital Input. When this pin is low, the device is disabled and all switches are turned off. When this pin is high, the Ax logic inputs determine which switch is turned on. 19 17 S1 Source Terminal 1. This pin can be an input or an output. 20 18 S2 Source Terminal 2. This pin can be an input or an output. 21 19 S3 Source Terminal 3. This pin can be an input or an output. 22 20 S4 Source Terminal 4. This pin can be an input or an output. 23 21 S5 Source Terminal 5. This pin can be an input or an output. 24 22 S6 Source Terminal 6. This pin can be an input or an output. 25 23 S7 Source Terminal 7. This pin can be an input or an output. 26 24 S8 Source Terminal 8. This pin can be an input or an output. 27 25 VSS Most Negative Power Supply Potential. In single-supply applications, this pin can be connected to ground. 28 29 D Drain Terminal. This pin can be an input or an output. EPAD Exposed Pad The exposed pad is connected internally. For increased reliability of the solder joints and maximum thermal capability, it is recommended that the pad be soldered to the substrate, VSS. Rev. A | Page 9 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
