Datasheet ADG1608, ADG1609 (Analog Devices) - 4
Description4.5 Ω RON, 8-Channel ±5 V,+12 V, +5 V, and +3.3 V Multiplexer
Pages / Page20 / 4 — ADG1608/ADG1609. Data Sheet. 12 V SINGLE SUPPLY. Table 2. −40°C to. …
File Format / SizePDF / 480 Kb
ADG1608/ADG1609. Data Sheet. 12 V SINGLE SUPPLY. Table 2. −40°C to. Parameter. 25°C. +85°C. +125°C. Unit. Test Conditions/Comments
ADG1608/ADG1609 Data Sheet 12 V SINGLE SUPPLY Table 2 −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 14 link to page 15 link to page 16 link to page 16 link to page 16 link to page 16
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 4 Ω typ VS = 0 V to 10 V, IS = −10 mA; see Figure 25 4.5 6.5 7.5 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match Between Channels (∆RON) 0.12 Ω typ VS = 10 V, IS = −10 mA 0.25 0.3 0.35 Ω max On-Resistance Flatness (RFLAT(ON)) 0.9 Ω typ VS = 0 V to 10 V, IS = −10 mA 1.2 1.6 1.9 Ω max LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.02 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 26 ±0.1 ±0.5 ±3 nA max Drain Off Leakage, ID (Off) ±0.03 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 26 ADG1608 ±0.15 ±2 ±14 nA max ADG1609 ±0.15 ±1 ±7 nA max Channel On Leakage, ID, IS (On) ±0.03 nA typ VS = VD = 1 V or 10 V; see Figure 27 ±0.15 ±2 ±14 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±1 nA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 113 ns typ RL = 300 Ω, CL = 35 pF 141 172 196 ns max VS = 8 V; see Figure 28 tON (EN) 80 ns typ RL = 300 Ω, CL = 35 pF 94 101 110 ns max VS = 8 V; see Figure 30 tOFF (EN) 77 ns typ RL = 300 Ω, CL = 35 pF 93 117 140 ns max VS = 8 V; see Figure 30 Break-Before-Make Time Delay, tD 47 ns typ RL = 300 Ω, CL = 35 pF 30 ns min VS1 = VS2 = 8 V; see Figure 29 Charge Injection 29 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 31 Off Isolation −64 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 32 Channel-to-Channel Crosstalk −64 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 34 Total Harmonic Distortion + Noise (THD + N) 0.04 % typ RL = 110 Ω, VS = 5 V p-p, f = 20 Hz to 20 kHz; see Figure 35 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 33 ADG1608 40 MHz typ ADG1609 78 MHz typ CS (Off) 19 pF typ VS = 6 V, f = 1 MHz CD (Off) ADG1608 117 pF typ VS = 6 V, f = 1 MHz ADG1609 59 pF typ VS = 6 V, f = 1 MHz CD, CS (On) ADG1608 149 pF typ VS = 6 V, f = 1 MHz ADG1609 84 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 12 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max ADG1608 300 µA typ Digital inputs = 5 V 480 µA max ADG1609 225 µA typ Digital inputs = 5 V 360 µA max VDD 3.3/16 V min/max 1 Guaranteed by design, but not subject to production test. Rev. A | Page 4 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
