Datasheet ADG1608, ADG1609 (Analog Devices) - 5
Description4.5 Ω RON, 8-Channel ±5 V,+12 V, +5 V, and +3.3 V Multiplexer
Pages / Page20 / 5 — Data Sheet. ADG1608/ADG1609. 5 V SINGLE SUPPLY. Table 3. −40°Cto. −40°C …
File Format / SizePDF / 480 Kb
Data Sheet. ADG1608/ADG1609. 5 V SINGLE SUPPLY. Table 3. −40°Cto. −40°C to. Parameter. 25°C. +85°C. +125°C. Unit. Test Conditions/Comments
Data Sheet ADG1608/ADG1609 5 V SINGLE SUPPLY Table 3 −40°Cto −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 14 link to page 15 link to page 16 link to page 16 link to page 16 link to page 16
VDD = 5 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. −40°Cto −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 8.5 Ω typ VS = 0 V to 4.5 V, IS = −10 mA; see Figure 25 10 12.5 14 Ω max VDD = 4.5 V, VSS = 0 V On-Resistance Match Between Channels (∆RON) 0.15 Ω typ VS = 0 V to 4.5 V, IS = −10 mA 0.3 0.35 0.4 Ω max On-Resistance Flatness (RFLAT(ON)) 1.7 Ω typ VS = 0 V to 4.5 V, IS = −10 mA 2.3 2.7 3 Ω max LEAKAGE CURRENTS VDD = 5.5 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.01 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 26 ±0.1 ±0.5 ±3 nA max Drain Off Leakage, ID (Off) ±0.01 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 26 ADG1608 ±0.15 ±2 ±14 nA max ADG1609 ±0.15 ±1 ±7 nA max Channel On Leakage, ID, IS (On) ±0.01 nA typ VS = VD = 1 V or 4.5 V; see Figure 27 ±0.15 ±2 ±14 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±1 nA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 193 ns typ RL = 300 Ω, CL = 35 pF 251 301 339 ns max VS = 2.5 V; see Figure 28 tON (EN) 115 ns typ RL = 300 Ω, CL = 35 pF 152 171 184 ns max VS = 2.5 V; see Figure 30 tOFF (EN) 140 ns typ RL = 300 Ω, CL = 35 pF 184 225 259 ns max VS = 2.5 V; see Figure 30 Break-Before-Make Time Delay, tD 66 ns typ RL = 300 Ω, CL = 35 pF 37 ns min VS1 = VS2 = 2.5 V; see Figure 29 Charge Injection 11 pC typ VS = 2.5 V, RS = 0 Ω, CL = 1 nF; see Figure 31 Off Isolation −64 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 32 Channel-to-Channel Crosstalk −64 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 34 Total Harmonic Distortion + Noise (THD + N) 0.3 % typ RL = 110 Ω, f = 20 Hz to 20 kHz, VS = 3.5 V p-p; see Figure 35 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 33 ADG1608 37 MHz typ ADG1609 72 MHz typ CS (Off) 22 pF typ VS = 2.5 V, f = 1 MHz CD (Off) VS = 2.5 V, f = 1 MHz ADG1608 136 pF typ ADG1609 68 pF typ CD, CS (On) VS = 2.5 V, f = 1 MHz ADG1608 168 pF typ ADG1609 94 pF typ POWER REQUIREMENTS VDD = 5.5 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max VDD 3.3/16 V min/max 1 Guaranteed by design, but not subject to production test. Rev. A | Page 5 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
