Datasheet ADG1608, ADG1609 (Analog Devices) - 6
Description4.5 Ω RON, 8-Channel ±5 V,+12 V, +5 V, and +3.3 V Multiplexer
Pages / Page20 / 6 — ADG1608/ADG1609. Data Sheet. 3.3 V SINGLE SUPPLY. Table 4. −40°C to. …
RevisionA
File Format / SizePDF / 480 Kb
ADG1608/ADG1609. Data Sheet. 3.3 V SINGLE SUPPLY. Table 4. −40°C to. Parameter. 25°C. +85°C. +125°C. Unit. Test Conditions/Comments
ADG1608/ADG1609 Data Sheet 3.3 V SINGLE SUPPLY Table 4 −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 14 link to page 15 link to page 16 link to page 16 link to page 16 link to page 16
VDD = 3.3 V, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 4. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 13.5 15 16.5 Ω typ VS = 0 V to VDD, IS = −10 mA; see Figure 25, VDD = 3.3 V, VSS = 0 V On-Resistance Match Between Channels (∆RON) 0.25 0.28 0.3 Ω typ VS = 0 V to VDD, IS = −10 mA On-Resistance Flatness (RFLAT(ON)) 5 5.5 6.5 Ω typ VS = 0 V to VDD, IS = −10 mA LEAKAGE CURRENTS VDD = 3.6 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.01 nA typ VS = 0.6 V/3 V, VD = 3 V/0.6 V; see Figure 26 ±0.1 ±0.5 ±3 nA max Drain Off Leakage, ID (Off) ±0.01 nA typ VS = 0.6 V/3 V, VD = 3 V/0.6 V; see Figure 26 ADG1608 ±0.15 ±2 ±14 nA max ADG1609 ±0.15 ±1 ±7 nA max Channel On Leakage, ID, IS (On) ±0.01 nA typ VS = VD = 0.6 V or 3 V; see Figure 27 ±0.15 ±2 ±14 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±1 nA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 312 ns typ RL = 300 Ω, CL = 35 pF 437 498 542 ns max VS = 1.5 V; see Figure 28 tON (EN) 216 ns typ RL = 300 Ω, CL = 35 pF 309 331 344 ns max VS = 1.5 V; see Figure 30 tOFF (EN) 236 ns typ RL = 300 Ω, CL = 35 pF 316 367 411 ns max VS = 1.5 V; see Figure 30 Break-Before-Make Time Delay, tD 104 ns typ RL = 300 Ω, CL = 35 pF 48 ns min VS1 = VS2 = 1.5 V; see Figure 29 Charge Injection 6 pC typ VS = 1.5 V, RS = 0 Ω, CL = 1 nF; see Figure 31 Off Isolation −64 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 32 Channel-to-Channel Crosstalk −64 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 34 Total Harmonic Distortion + Noise (THD + N) 0.5 % typ RL = 110 Ω, f = 20 Hz to 20 kHz, VS = 2 V p-p; see Figure 35 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 33 ADG1608 34 MHz typ ADG1609 72 MHz typ CS (Off) 23 pF typ VS = 1.5 V, f = 1 MHz CD (Off) VS = 1.5 V, f = 1 MHz ADG1608 145 pF typ ADG1609 72 pF typ CD, CS (On) VS = 1.5 V, f = 1 MHz ADG1608 173 pF typ ADG1609 95 pF typ POWER REQUIREMENTS VDD = 3.6 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max VDD 3.3/16 V min/max 1 Guaranteed by design, but not subject to production test. Rev. A | Page 6 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
