Datasheet ADG1633, ADG1634 (Analog Devices)
Description4.5 Ω RON, Triple/Quad SPDT ±5 V, +12 V, +5 V, and +3.3 V Switches
Pages / Page19 / 1 — 4.5 Ω RON, Triple/Quad SPDT ±5 V,. +12 V, +5 V, and +3.3 V Switches. Data …
RevisionB
File Format / SizePDF / 445 Kb
4.5 Ω RON, Triple/Quad SPDT ±5 V,. +12 V, +5 V, and +3.3 V Switches. Data Sheet. ADG1633/. ADG1634. FEATURES
Datasheet ADG1633, ADG1634 Analog Devices, Revision: B
4.5 Ω RON, Triple/Quad SPDT ±5 V, +12 V, +5 V, and +3.3 V Switches Data Sheet ADG1633/ ADG1634 FEATURES FUNCTIONAL BLOCK DIAGRAMS 4.5 Ω typical on resistance ADG1633 1 Ω on-resistance flatness S1A Up to 206 mA continuous current D1 ±3.3 V to ±8 V dual-supply operation S1B 3.3 V to 16 V single-supply operation S3B D3 No VL supply required S2B S3A 3 V logic-compatible inputs D2 Rail-to-rail operation S2A ADG1633 LOGIC 16-lead TSSOP and 16-lead, 3 mm × 3 mm LFCSP ADG1634 IN1 IN2 IN3 EN 20-lead TSSOP and 20-lead, 4 mm × 4 mm LFCSP
001
SWITCHES SHOWN FOR A 1 INPUT LOGIC. APPLICATIONS
08319- Figure 1. ADG1633 TSSOP and LFCSP
Communication systems Medical systems Audio signal routing ADG1634 Video signal routing S1A S4A Automatic test equipment D1 D4 Data acquisition systems S1B S4B Battery-powered systems IN1 IN4 Sample-and-hold systems Relay replacements IN2 IN3 S2B S3B GENERAL DESCRIPTION D2 D3
The ADG1633 and ADG1634 are monolithic industrial CMOS
S2A S3A
(iCMOS®) analog switches comprising three independently selectable single-pole, double-throw (SPDT) switches and 002
SWITCHES SHOWN FOR
four independently selectable SPDT switches, respectively.
A 1 INPUT LOGIC.
08319- All channels exhibit break-before-make switching action that Figure 2. ADG1634 TSSOP prevents momentary shorting when switching channels. An EN input on the ADG1633 (LFCSP and TSSOP packages) and ADG1634 (LFCSP package only) is used to enable or disable
ADG1634 S1A S4A
the devices. When disabled, all channels are switched off.
D1 D4
The ultralow on resistance and on-resistance flatness of these
S1B S4B
switches make them ideal solutions for data acquisition and gain switching applications, where low distortion is critical. iCMOS
S2B S3B D2 D3
construction ensures ultralow power dissipation, making the parts
S2A S3A
ideally suited for portable and battery-powered instruments.
LOGIC IN1 IN2 IN3 IN4 EN
003
08319- Figure 3. ADG1634 LFCSP
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2009–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
