Datasheet ADG1634-KGD (Analog Devices) - 3
Description4.5 Ω RON, Quad SPDT ±5 V, +12 V, +5 V, and +3.3 V Switch
Pages / Page13 / 3 — Data Sheet. ADG1634-KGD. SPECIFICATIONS ±5 V DUAL SUPPLY. Table 1. −40°C …
File Format / SizePDF / 368 Kb
Data Sheet. ADG1634-KGD. SPECIFICATIONS ±5 V DUAL SUPPLY. Table 1. −40°C to −40°C to. Parameter. 25°C. +85°C. +125°C. Unit
Data Sheet ADG1634-KGD SPECIFICATIONS ±5 V DUAL SUPPLY Table 1 −40°C to −40°C to Parameter 25°C +85°C +125°C Unit
link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 4
VDD = +5 V ± 10%, VSS = −5 V ± 10%, and GND = 0 V, unless otherwise noted.
Table 1. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 4.5 Ω typ Supply voltage (VS) = ±4.5 V, supply current (IS) = −10 mA, see Figure 3 5 7 8 Ω max VDD = ±4.5 V, VSS = ±4.5 V On-Resistance Match Between Channels, ΔRON 0.12 Ω typ VS = ±4.5 V, IS = −10 mA 0.25 0.3 0.35 Ω max On-Resistance Flatness, RFLAT(ON) 1 Ω typ VS = ±4.5 V, IS = −10 mA 1.3 1.7 2 Ω max LEAKAGE CURRENTS VDD = +5.5 V, VSS = −5.5 V Source Off Leakage, IS (Off) ±0.01 nA typ VS = ±4.5 V, drain voltage (VD) = ±4.5 V, see Figure 4 ±0.1 ±1.5 ±12 nA max Drain Off Leakage, ID (Off) ±0.02 nA typ VS = ±4.5 V, VD = ±4.5 V, see Figure 4 ±0.15 ±2 ±20 nA max Channel On Leakage, ID, IS (On) ±0.02 nA typ VS = VD = ±4.5 V, see Figure 5 ±0.15 ±2 ±20 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±1 nA typ Input voltage (VIN) = GND voltage (VGND) or VDD ±0.1 µA max Digital Input Capacitance, CIN 8 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 161 ns typ Load resistance (RL) = 300 Ω, load capacitance (CL) = 35 pF 200 236 264 ns max VS = 2.5 V, see Figure 6 tON (EN) 61 ns typ RL = 300 Ω, CL = 35 pF 79 88 98 ns max VS = 2.5 V, see Figure 8 tOFF (EN) 162 ns typ RL = 300 Ω, CL = 35 pF 199 232 259 ns max VS = 2.5 V, see Figure 8 Break-Before-Make Time Delay, tD 44 ns typ RL = 300 Ω, CL = 35 pF 30 ns min S1x voltage (VS1x) = S2x voltage (VS2x) = 2.5 V, see Figure 7 Charge Injection −12.5 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF, see Figure 9 Off Isolation −64 dB typ RL = 50 Ω, CL = 5 pF, frequency (f) = 1 MHz, see Figure 10 Channel-to-Channel Crosstalk −64 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 12 Total Harmonic Distortion + Noise, THD + N 0.3 % typ RL = 110 Ω, VS = 5 V p-p, f = 20 Hz to 20 kHz, see Figure 13 −3 dB Bandwidth 103 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 11 Source Capacitance Off, CS (Off) 19 pF typ VS = 0 V, f = 1 MHz Drain Capacitance Off, CD (Off) 33 pF typ VS = 0 V, f = 1 MHz Source and Drain Capacitance On, CD, CS (On) 57 pF typ VS = 0 V, f = 1 MHz Rev. 0 | Page 3 of 13 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TEST CIRCUITS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
