Datasheet ADG1634-KGD (Analog Devices) - 9
Description4.5 Ω RON, Quad SPDT ±5 V, +12 V, +5 V, and +3.3 V Switch
Pages / Page13 / 9 — Data Sheet. ADG1634-KGD. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. …
File Format / SizePDF / 368 Kb
Data Sheet. ADG1634-KGD. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. S1A. DNC. S4A. DNC DNC. S1B. S4B. VSS. VDD. GND. S2B. S3B. NOTES
Data Sheet ADG1634-KGD PIN CONFIGURATION AND FUNCTION DESCRIPTIONS S1A DNC S4A DNC DNC S1B S4B VSS VDD GND S2B S3B NOTES
Data Sheet ADG1634-KGD PIN CONFIGURATION AND FUNCTION DESCRIPTIONS 1 4 S1A IN DNC EN IN DNC DNC S4A S4A S1A DNC DNC DNC D1 D4 D1 D4 S1B S4B ADG1634-KGD S1B S4B VSS VDD GND DNC DNC S2B S3B S2B S3B A A 2 3 A A D2 D2 D3 D3 S2 S2 IN IN S3 S3 DNC DNC
2 00
NOTES
8-
1. DNC = DO NOT CONNECT. DO NOT CONNECT TO THIS PAD.
2263 Figure 2. Pad Configuration
Table 7. Pad Function Descriptions Pad No. Mnemonic X Coordinate Y Coordinate Description
1 S1A −710 +710 Source Terminal 1A. This pad can be an input or an output. 2 DNC Not applicable Not applicable Do Not Connect. Do not connect to this pad. 3 D1 −710 +413 Drain Terminal 1. This pad can be an input or an output. 4 D1 −710 +328 Drain Terminal 1. This pad can be an input or an output. 5 S1B −710 +55 Source Terminal 1B. This pad can be an input or an output. 6 S1B −710 −30 Source Terminal 1B. This pad can be an input or an output. 7 VSS −710 −117 Most Negative Power Supply Potential. In single-supply applications, connect this pad to ground. 8 GND −710 −203 Ground (0 V) Reference. 9 DNC Not applicable Not applicable Do Not Connect. Do not connect to this pad. 10 S2B −710 −480 Source Terminal 2B. This pad can be an input or an output. 11 S2B −710 −565 Source Terminal 2B. This pad can be an input or an output. 12 D2 −641 −651 Drain Terminal 2. This pad can be an input or an output. 13 D2 −545 −710 Drain Terminal 2. This pad can be an input or an output. 14 DNC Not applicable Not applicable Do Not Connect. Do not connect to this pad. 15 S2A −215 −710 Source Terminal 2A. This pad can be an input or an output. 16 S2A −130 −710 Source Terminal 2A. This pad can be an input or an output. 17 IN2 −43 −710 Logic Control Input 2. 18 IN3 +43 −710 Logic Control Input 3. 19 S3A +130 −710 Source Terminal 3A. This pad can be an input or an output. 20 S3A +215 −710 Source Terminal 3A. This pad can be an input or an output. 21 DNC Not applicable Not applicable Do Not Connect. Do not connect to this pad. 22 D3 +545 −710 Drain Terminal 2. This pad can be an input or an output. 23 D3 +641 −651 Drain Terminal 2. This pad can be an input or an output. Rev. 0 | Page 9 of 13 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TEST CIRCUITS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
