Datasheet ADG1636 (Analog Devices) - 10
Description1 Ω Typical On Resistance, ±5 V, +12 V, +5 V, and +3.3 V Dual SPDT Switches
Pages / Page16 / 10 — ADG1636. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 1.4. TA = 25°C. …
File Format / SizePDF / 440 Kb
ADG1636. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 1.4. TA = 25°C. VDD = 12V. SS = 0V. DD = +3.3V. VSS = –3.3V. 1.2. TA = +125°C
ADG1636 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 1.4 TA = 25°C VDD = 12V SS = 0V DD = +3.3V VSS = –3.3V 1.2 TA = +125°C
ADG1636 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 1.4 1.4 TA = 25°C VDD = 12V V V SS = 0V DD = +3.3V VSS = –3.3V 1.2 1.2 TA = +125°C ) ) TA = +85°C TA = +25°C TA = –40°C 1.0 1.0 ANCE ANCE T T V IS DD = +5V IS S VSS = –5V S 0.8 0.8 N RE N RE O O VDD = +8V VSS = –8V 0.6 0.6 0.4 0.4 –8 –6 –4 –2 0 2 4 6 8 0 2 4 6 8 10 12
014 011
V V S OR VD VOLTAGE (V) S OR VD VOLTAGE (V)
07983- 07983- Figure 5. On Resistance as a Function of VD (VS) for Dual Supply Figure 8. On Resistance as a Function of VD (VS) for Different Temperatures, 12 V Single Supply
3.5 2.5 T V A = 25°C DD = 5V TA T = +125°C A = +125° VSS = 0V TA T = +85°C A = +85° 3.0 TA T = +25°C A = +25° T V A = –40°C A = –40° DD = 3.3V ) VSS = 0V ) 2.5 2.0 ANCE ANCE T 2.0 T IS IS S VDD = 5V S VSS = 0V N RE 1.5 N RE 1.5 O O VDD = 12V 1.0 VSS = 0V VDD = 16V VSS = 0V 0.5 1.0 0 2 4 6 8 10 12 14 16
015
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0
013
VS OR VD VOLTAGE (V) V
07983-
S OR VD VOLTAGE (V)
07983- Figure 6. On Resistance as a Function of VD (VS) for Single Supply Figure 9. On Resistance as a Function of VD (VS) for Different Temperatures, 5 V Single Supply
1.4 4.0 VDD = 3.3V VSS = 0V 1.2 3.5 ) ) 1.0 3.0 ANCE ANCE T T IS IS S S 0.8 2.5 TA = +125°C TA = +85°C N RE N RE T O O A = +25°C TA = –40°C 0.6 2.0 TA T = +125°C A = +125° TA T = +85°C A = +85° VDD = +5V TA T = +25°C A = +25° VSS = –5V TA T = –40°C A = –40° 0.4 1.5 –6 –4 –2 0 2 4 6
012
007
07983-
S OR VD VOLTAGE (V)
07983- Figure 7. On Resistance as a Function of VD (VS) for Different Temperatures, Figure 10. On Resistance as a Function of VD (VS) for Different Temperatures, ±5 V Dual Supply 3.3 V Single Supply Rev. B | Page 10 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
