Datasheet ADG1636 (Analog Devices)
Description | 1 Ω Typical On Resistance, ±5 V, +12 V, +5 V, and +3.3 V Dual SPDT Switches |
Pages / Page | 16 / 1 — 1 Ω Typical On Resistance, ±5 V, +12 V,. +5 V, and +3.3 V Dual SPDT … |
Revision | B |
File Format / Size | PDF / 440 Kb |
1 Ω Typical On Resistance, ±5 V, +12 V,. +5 V, and +3.3 V Dual SPDT Switches. Data Sheet. ADG1636. FEATURES
1 Ω Typical On Resistance, ±5 V, +12 V, +5 V, and +3.3 V Dual SPDT Switches Data Sheet ADG1636 FEATURES FUNCTIONAL BLOCK DIAGRAMS 1 Ω typical on resistance ADG1636 0.2 Ω on resistance flatness S1A ±3.3 V to ±8 V dual supply operation D1 3.3 V to 16 V single supply operation S1B No VL supply required IN1 3 V logic-compatible inputs Rail-to-rail operation IN2 Continuous current per channel LFCSP: 385 mA S2A TSSOP: 238 mA D2 16-lead TSSOP and 16-lead, 4 mm × 4 mm LFCSP S2B
1 00 3-
NOTES APPLICATIONS
98
1. SWITCHES SHOWN FOR A LOGIC 1 INPUT.
07 Figure 1. 16-Lead TSSOP
Communication systems Medical systems Audio signal routing ADG1636 S1A S2A Video signal routing D1 D2 Automatic test equipment S1B S2B Data acquisition systems Battery-powered systems LOGIC Sample-and-hold systems Relay replacements IN1 IN2 EN
02 0 3-
NOTES
798
1. SWITCHES SHOWN FOR A 1 INPUT LOGIC.
0 Figure 2. 16-Lead LFCSP
GENERAL DESCRIPTION
The CMOS construction ensures ultralow power dissipation, The ADG1636 is a monolithic CMOS device containing two making the devices ideally suited for portable and battery- independently selectable single-pole/double-throw (SPDT) powered instruments. switches. An EN input is used to enable or disable the device.
PRODUCT HIGHLIGHTS
When disabled, all channels are switched off. Each switch conducts 1. 1.6 Ω maximum on resistance over temperature. equally well in both directions when on and has an input signal 2. Minimum distortion: THD + N = 0.007%. range that extends to the supplies. In the off condition, signal 3. 3 V logic-compatible digital inputs: VINH = 2.0 V, VINL = 0.8 V. levels up to the supplies are blocked. Both switches exhibit 4. No VL logic power supply required. break-before-make switching action for use in multiplexer 5. Ultralow power dissipation: <16 nW. applications. 6. 16-lead TSSOP and 16-lead 4 mm × 4 mm LFCSP. The ultralow on resistance of these switches make them ideal solutions for data acquisition and gain switching applications where low on resistance and distortion is critical. The on resistance profile is very flat over the full analog input range, ensuring excellent linearity and low distortion when switching audio signals.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2009–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
