Datasheet ADG1636 (Analog Devices) - 3
Description1 Ω Typical On Resistance, ±5 V, +12 V, +5 V, and +3.3 V Dual SPDT Switches
Pages / Page16 / 3 — Data Sheet. ADG1636. SPECIFICATIONS ±5 V DUAL SUPPLY. Table 1. −40°C to …
File Format / SizePDF / 440 Kb
Data Sheet. ADG1636. SPECIFICATIONS ±5 V DUAL SUPPLY. Table 1. −40°C to −40°C to. Parameter. 25°C. +85°C. +125°C. Unit
Data Sheet ADG1636 SPECIFICATIONS ±5 V DUAL SUPPLY Table 1 −40°C to −40°C to Parameter 25°C +85°C +125°C Unit
link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 13 link to page 13 link to page 14 link to page 13
VDD = +5 V ± 10%, VSS = −5 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance (RON) 1 Ω typ VS = ±4.5 V, IS = −10 mA; see Figure 23 1.2 1.4 1.6 Ω max VDD = ±4.5 V, VSS = ±4.5 V On Resistance Match Between Channels (∆RON) 0.04 Ω typ VS = ±4.5 V, IS = −10 mA 0.08 0.09 0.1 Ω max On Resistance Flatness (RFLAT(ON)) 0.2 Ω typ VS = ±4.5 V, IS = −10 mA 0.25 0.29 0.34 Ω max LEAKAGE CURRENTS VDD = +5.5 V, VSS = −5.5 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 24 ±0.25 ±1 ±4 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = ±4.5V, VD = ∓4.5 V; see Figure 24 ±0.25 ±2 ±10 nA max Channel On Leakage, ID, IS (On) ±0.3 nA typ VS = VD = ±4.5 V; see Figure 25 ±0.6 ±2 ±12 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 5 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 130 ns typ RL = 300 Ω, CL = 35 pF 209 245 273 ns max VS = 2.5 V; see Figure 30 tON (EN) 119 ns typ RL = 300 Ω, CL = 35 pF 148 166 176 ns max VS = 2.5 V; see Figure 30 tOFF (EN) 182 ns typ RL = 300 Ω, CL = 35 pF 228 259 281 ns max VS = 2.5 V; see Figure 30 Break-Before-Make Time Delay, tD 30 ns typ RL = 300 Ω, CL = 35 pF 17 ns min VS1 = VS2 = 2.5 V; see Figure 31 Charge Injection 130 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 32 Off Isolation 70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 26 Channel-to-Channel Crosstalk 90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 Total Harmonic Distortion + Noise (THD + N) 0.007 % typ RL = 110 Ω, 5 V p-p, f = 20 Hz to 20 kHz; see Figure 29 −3 dB Bandwidth 25 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 27 CS (Off) 68 pF typ VS = 0 V, f = 1 MHz CD (Off) 127 pF typ VS = 0 V, f = 1 MHz CD, CS (On) 220 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +5.5 V, VSS = −5.5 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max VDD/VSS ±3.3/±8 V min/max 1 Guaranteed by design, not subject to production test. Rev. B | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
