Datasheet ADG1636 (Analog Devices) - 5
Description1 Ω Typical On Resistance, ±5 V, +12 V, +5 V, and +3.3 V Dual SPDT Switches
Pages / Page16 / 5 — Data Sheet. ADG1636. 5 V SINGLE SUPPLY. Table 3. −40°C to −40°C to. …
File Format / SizePDF / 440 Kb
Data Sheet. ADG1636. 5 V SINGLE SUPPLY. Table 3. −40°C to −40°C to. Parameter. 25°C +85°C. 125°C. Unit. Test Conditions/Comments
Data Sheet ADG1636 5 V SINGLE SUPPLY Table 3 −40°C to −40°C to Parameter 25°C +85°C 125°C Unit Test Conditions/Comments
link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 13 link to page 13 link to page 14 link to page 13
VDD = 5 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. −40°C to −40°C to Parameter 25°C +85°C 125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 1.7 Ω typ VS = 0 V to 4.5 V, IS = −10 mA; see Figure 23 2.15 2.4 2.7 Ω max VDD = 4.5 V, VSS = 0 V On Resistance Match Between Channels (∆RON) 0.05 Ω typ VS = 0 V to 4.5 V, IS = −10 mA 0.09 0.12 0.15 Ω max On Resistance Flatness (RFLAT(ON)) 0.4 Ω typ VS = 0 V to 4.5 V, IS = −10 mA 0.53 0.55 0.6 Ω max LEAKAGE CURRENTS VDD = 5.5 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.05 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 24 ±0.25 ±1 ±4 nA max Drain Off Leakage, ID (Off) ±0.05 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V; see Figure 24 ±0.25 ±2 ±10 nA max Channel On Leakage, ID, IS (On) ±0.1 nA typ VS = VD = 1 V or 4.5 V; see Figure 25 ±0.6 ±2 ±12 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.001 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 5 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 160 ns typ RL = 300 Ω, CL = 35 pF 271 319 355 ns max VS = 2.5 V; see Figure 30 tON (EN) 132 ns typ RL = 300 Ω, CL = 35 pF 172 185 201 ns max VS = 2.5 V; see Figure 30 tOFF (EN) 210 ns typ RL = 300 Ω, CL = 35 pF 268 313 345 ns max VS = 2.5 V; see Figure 30 Break-Before-Make Time Delay, tD 30 ns typ RL = 300 Ω, CL = 35 pF 17 ns min VS1 = VS2 = 2.5 V; see Figure 31 Charge Injection 70 pC typ VS = 2.5 V, RS = 0 Ω, CL = 1 nF; see Figure 32 Off Isolation 70 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 26 Channel-to-Channel Crosstalk 90 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 28 Total Harmonic Distortion + Noise (THD + N) 0.09 % typ RL = 110 Ω, f = 20 Hz to 20 kHz, VS = 3.5 V p-p; see Figure 29 −3 dB Bandwidth 26 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 27 CS (Off) 76 pF typ VS = 2.5 V, f = 1 MHz CD (Off) 145 pF typ VS = 2.5 V, f = 1 MHz CD, CS (On) 237 pF typ VS = 2.5 V, f = 1 MHz POWER REQUIREMENTS VDD = 5.5 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 1.0 µA max VDD 3.3/16 V min/max 1 Guaranteed by design, not subject to production test. Rev. B | Page 5 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
