Datasheet ADG1411, ADG1412, ADG1413 (Analog Devices) - 6
Description1.5 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS, Quad SPST Switches
Pages / Page16 / 6 — ADG1411/ADG1412/ADG1413. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 4. …
RevisionD
File Format / SizePDF / 410 Kb
ADG1411/ADG1412/ADG1413. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter. Rating. ESD CAUTION
ADG1411/ADG1412/ADG1413 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
Table 4.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a VDD to VSS 35 V stress rating only; functional operation of the product at these VDD to GND −0.3 V to +25 V or any other conditions above those indicated in the operational VSS to GND +0.3 V to −25 V section of this specification is not implied. Operation beyond Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or the maximum operating conditions for extended periods may 30 mA, whichever occurs first affect product reliability. Digital Inputs1 GND − 0.3 V to VDD + 0.3 V or Only one absolute maximum rating may be applied at any 30 mA, whichever occurs first one time. Peak Current, Sx or Dx Pins 500 mA (pulsed at 1 ms, 10% duty cycle maximum)
ESD CAUTION
Continuous Current per Channel at 25°C 16-Lead TSSOP 190 mA 16-Lead LFCSP 250 mA Continuous Current per Channel at 125°C 16-Lead TSSOP 90 mA 16-Lead LFCSP 100 mA Operating Temperature Range Automotive (Y Version) −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C θJA Thermal Impedance 16-Lead TSSOP (4-Layer Board) 112°C/W 16-Lead LFCSP 30.4°C/W Reflow Soldering Peak 260(+0/−5)°C Temperature, Pb Free 1 Overvoltages at the INx, Sx, and Dx pins are clamped by internal diodes. Current should be limited to the maximum ratings given. Rev. D | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
