Datasheet ADG1411, ADG1412, ADG1413 (Analog Devices) - 7
Description1.5 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS, Quad SPST Switches
Pages / Page16 / 7 — Data Sheet. ADG1411/ADG1412/ADG1413. PIN CONFIGURATIONS AND FUNCTION …
RevisionD
File Format / SizePDF / 410 Kb
Data Sheet. ADG1411/ADG1412/ADG1413. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. IN1 1. 16 IN2. S1 1. 12 S2. D1 2. 15 D2. ADG1411/. VDD
Data Sheet ADG1411/ADG1412/ADG1413 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS IN1 1 16 IN2 S1 1 12 S2 D1 2 15 D2 ADG1411/ VDD
Data Sheet ADG1411/ADG1412/ADG1413 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS 1 2 D1 IN IN D2 61 5 3 1 41 1 IN1 1 16 IN2 S1 1 12 S2 D1 2 15 D2 V 2 ADG1411/ 11 SS VDD S1 3 ADG1411/ 14 S2 ADG1412/ ADG1412/ GND 3 10 NIC ADG1413 VSS 4 13 VDD ADG1413 S4 4 9 S3 GND 5 12 NIC TOP VIEW S4 6 (Not to Scale) 11 S3 5 6 7 8 4 3 D4 7 10 D3 D4 IN IN D3 IN4 8 9 IN3 TOP VIEW (Not to Scale)
3 002
NOTES
00
NOTES
15- 5-
1. NIC = NO INTERNAL CONNECTION. 1. NIC = NO INTERNAL CONNECTION.
81 068
2. TIE THE EXPOSED PAD TO THE SUBSTRATE, VSS.
06 Figure 2. TSSOP Pin Configuration Figure 3. LFCSP Pin Configuration
Table 5. Pin Function Descriptions Pin No. TSSOP LFCSP Mnemonic Description
1 15 IN1 Logic Control Input. 2 16 D1 Drain Terminal. This pin can be an input or output. 3 1 S1 Source Terminal. This pin can be an input or output. 4 2 VSS Most Negative Power Supply Potential. 5 3 GND Ground (0 V) Reference. 6 4 S4 Source Terminal. This pin can be an input or output. 7 5 D4 Drain Terminal. This pin can be an input or output. 8 6 IN4 Logic Control Input. 9 7 IN3 Logic Control Input. 10 8 D3 Drain Terminal. This pin can be an input or output. 11 9 S3 Source Terminal. This pin can be an input or output. 12 10 NIC No Internal Connection. 13 11 VDD Most Positive Power Supply Potential. 14 12 S2 Source Terminal. This pin can be an input or output. 15 13 D2 Drain Terminal. This pin can be an input or output. 16 14 IN2 Logic Control Input. N/A1 0 EPAD Exposed Pad. Tie the exposed pad to the substrate, VSS. 1 N/A means not applicable.
Table 6. ADG1411/ ADG1412 Truth Table ADG1411 INx ADG1412 INx Switch Condition
0 1 On 1 0 Off
Table 7. ADG1413 Truth Tabl e ADG1413 INx S1, S4 S2, S3
0 Off On 1 On Off Rev. D | Page 7 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
