link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 13 link to page 13 link to page 13 link to page 13 ADG1436Data Sheet12 V SINGLE SUPPLY VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted. Table 2. Parameter25°C−40°C to +85°C−40°C to +125°CUnitTest Conditions/Comments ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 2.8 Ω typ VS = 0 V to 10 V, IS = −10 mA; see Figure 23 3.5 4.3 4.8 Ω max VDD = +10.8 V, VSS = 0 V On-Resistance Match 0.13 Ω typ VS = 0 V to 10 V, IS = −10 mA Between Channels (∆RON) 0.21 0.23 0.25 Ω max On-Resistance Flatness (RFLAT(ON)) 0.6 Ω typ VS = 0 V to 10 V, IS = −10 mA 1.1 1.2 1.3 Ω max LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.04 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 24 ±0.55 ±2 ±12.5 nA max Drain Off Leakage, ID (Off) ±0.04 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 24 ±0.55 ±2 ±12.5 nA max Channel On Leakage, ID, IS (On) ±0.1 nA typ VS = VD = 1 V or 10 V; see Figure 25 ±1 ±4 ±35 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.001 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3.5 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 200 ns typ RL = 300 Ω, CL = 35 pF 270 320 350 ns max VS = 8 V; see Figure 30 tON (EN) 175 ns typ RL = 300 Ω, CL = 35 pF 235 280 310 ns max VS = 8 V; see Figure 30 tOFF (EN) 105 ns typ RL = 300 Ω, CL = 35 pF 145 175 195 ns max VS = 8 V; see Figure 30 Break-Before-Make Time Delay, tBBM 70 ns typ RL = 300 Ω, CL = 35 pF 10 ns min VS1 = VS2 = 8 V; see Figure 31 Charge Injection 30 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 33 Off Isolation −80 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 26; Channel-to-Channel Crosstalk −80 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 27 −3 dB Bandwidth 78 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 28 Insertion Loss −0.3 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 CS (Off) 40 pF typ f = 1 MHz, VS = 6 V CD (Off) 80 pF typ f = 1 MHz, VS = 6 V CD, CS (On) 140 pF typ f = 1 MHz, VS = 6 V POWER REQUIREMENTS VDD = 13.2 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max IDD 170 µA typ Digital inputs = 5 V 285 µA max VDD 5/16.5 V min/max GND = 0 V, VSS = 0 V 1 Guaranteed by design, not subject to production test. Rev. B | Page 4 of 16 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications 15 V Dual Supply 12 V Single Supply 5 V Dual Supply Continuous Current per Channel Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table For Switches Typical Performance Characteristics Terminology Test Circuits Outline Dimensions Ordering Guide
