Datasheet ADG1436 (Analog Devices) - 10
Description | 1.5 Ω On Resistance, ±15 V/12 V/±5 V, iCMOS, Dual SPDT Switch |
Pages / Page | 16 / 10 — ADG1436. Data Sheet. TA = 25°C I. DD PER LOGIC INPUT. S (OFF) + –. D … |
Revision | B |
File Format / Size | PDF / 504 Kb |
ADG1436. Data Sheet. TA = 25°C I. DD PER LOGIC INPUT. S (OFF) + –. D (OFF) + –. S (OFF) – +. µ (. ID (OFF) – +. DD = +15V. AKAG. I DD
ADG1436 Data Sheet 2 80 TA = 25°C I 1 DD PER LOGIC INPUT 70 0 60 –1 I A) S (OFF) + – 50 n I ( –2 D (OFF) + – E I A) S (OFF) – + µ ( 40 ID (OFF) – + V –3 DD = +15V AKAG I I DD D, IS (ON) + + V E SS = –15V V L I DD = +12V D, IS (ON) – – 30 –4 VSS = 0V 20 –5 V –6 DD = +15V 10 V V DD = +5V SS = –15V V V SS = –5V BIAS = +10V/–10V –7 0 0 20 40 60 80 100 120
111
0 2 4 6 8 10 12 14
008
TEMPERATURE (°C) LOGIC, Ax (V)
06817- 06817- Figure 11. Leakage Currents vs. Temperature, 15 V Dual Supply Figure 14. IDD vs. Logic Level
1.5 600 TA = 25°C 1.0 400 V 0.5 DD = +15V, VSS = –15V C) p 200 N ( A) 0 n IO V ( DD = +5V, VSS = –5V E IS (OFF) + – CT –0.5 ID (OFF) + – 0 I NJE AKAG S (OFF) – + I V E E DD = +12V, VSS = 0V –1.0 I L D (OFF) – + ID, IS (ON) + + –200 ID, IS (ON) – – –1.5 CHARG –400 –2.0 VDD = +5V VSS = –5V VBIAS = +4.5V/–4.5V –2.5 –600 0 20 40 60 80 100 120
113
–15 –10 –5 0 5 10 15
012
TEMPERATURE (°C) V
06817-
S (V)
06817- Figure 12. Leakage Currents vs. Temperature, 5 V Dual Supply Figure 15. Charge Injection vs. Source Voltage
8 450 7 400 V 6 DD = +5V 350 VSS = –5V 5 I 300 A) S (OFF) + – n 4 I ( D (OFF) + – ) V s DD = +12V E I 250 S (OFF) – + V 3 SS = 0V ID (OFF) – + AKAG I IME (n 200 2 D, IS (ON) + + E T L ID, IS (ON) – – 150 1 VDD = +15V VSS = –15V 0 100 VDD = 12V –1 V 50 SS = 0V VBIAS = 1V/10V –2 0 0 20 40 60 80 100 120
112
–40 –20 0 20 40 60 80 100 120
217
TEMPERATURE (°C)
06817-
TEMPERATURE (°C)
06817- Figure 13. Leakage Currents vs. Temperature, 12 V Single Supply Figure 16. tTRANSITION Time vs. Temperature Rev. B | Page 10 of 16 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications 15 V Dual Supply 12 V Single Supply 5 V Dual Supply Continuous Current per Channel Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table For Switches Typical Performance Characteristics Terminology Test Circuits Outline Dimensions Ordering Guide
