Datasheet ADG1219 (Analog Devices) - 8
DescriptionLow Capacitance, Low Charge Injection, ±15 V/12 V iCMOS SPDT in SOT-23
Pages / Page16 / 8 — ADG1219. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 250. A = 25°C. DD = …
File Format / SizePDF / 391 Kb
ADG1219. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 250. A = 25°C. DD = 15V. 180. SS = –15V. 160. VDD = 13.5V. VSS = –13.5V. A = +125°C. 140
ADG1219 TYPICAL PERFORMANCE CHARACTERISTICS 200 250 A = 25°C DD = 15V 180 SS = –15V 160 VDD = 13.5V VSS = –13.5V A = +125°C 140
ADG1219 TYPICAL PERFORMANCE CHARACTERISTICS 200 250 T V A = 25°C V DD = 15V 180 DD = 15V V V SS = –15V SS = –15V 160 VDD = 13.5V 200 VSS = –13.5V T ) A = +125°C 140 ) ( ( TA = +85°C 120 150 TANCE T 100 VDD = 16.5V TANCE A = +25°C IS IS S VSS = –16.5V S 80 100 N RE N RE TA = –40°C O 60 O 40 50
04
20
07 0 0 5- 5- 57 57
0
06
0
06
–18 –15 –12 –9 –6 –3 0 3 6 9 12 15 18 –15 –10 –5 0 5 10 15 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (°C)
Figure 4. On Resistance as a Function of VD (VS) for Dual Supply Figure 7. On Resistance as a Function of VD (VS) for Different Temperatures, Dual Supply
600 600 T V A = 25°C VDD = 4.5V DD = 12V V V SS = –4.5V SS = 0V TA = +125°C 500 500 VDD = 5V ) VSS = –5V ) TA = +85°C ( 400 ( 400 TA = +25°C TANCE 300 VDD = 5.5V TANCE 300 IS IS S VSS = –5.5V S N RE N RE TA = –40°C O 200 O 200 100 100
05 08 0 0 5- 5- 57 57
0
06
0
06
–6 –4 –2 0 2 4 6 0 2 4 6 8 10 12 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (°C)
Figure 5. On Resistance as a Function of VD (VS) for Dual Supply Figure 8. On Resistance as a Function of VD (VS) for Different Temperatures, Single Supply
450 0.6 TA = 25°C VDD = 10.8V VDD = 15V 400 V V SS = 0V 0.4 SS = –15V VBIAS = +10V/–10V 350 VDD = 12V 0.2 ) VSS = 0V Ω ( 300 A) 0 n 250 ( E TANCE VDD = 13.2V G –0.2 IS S 200 VSS = 0V AKA E L –0.4 IS(OFF)+– N RE O 150 ID(OFF)+– –0.6 IS(OFF)–+ 100 ID(OFF)–+ 50 –0.8 I
06
D, IS(ON)++
30 0 0 5- 5-
ID, IS(ON)– –
57 57
0
06
–1.0
06
0 2 4 6 8 10 12 14 0 20 40 60 80 100 120 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (°C)
Figure 6. On Resistance as a Function of VD (VS) for Single Supply Figure 9. Leakage Currents as a Function of Temperature, 15 V Dual Supply Rev. A | Page 8 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
