Datasheet ADG1219 (Analog Devices) - 9
Description | Low Capacitance, Low Charge Injection, ±15 V/12 V iCMOS SPDT in SOT-23 |
Pages / Page | 16 / 9 — ADG1219. 0.6. 0.5. DD = 12V. S(OFF)+–. A = 25ºC. 0.4. SS = 0V. ID(OFF)+–. … |
Revision | A |
File Format / Size | PDF / 391 Kb |
ADG1219. 0.6. 0.5. DD = 12V. S(OFF)+–. A = 25ºC. 0.4. SS = 0V. ID(OFF)+–. VBIAS = 1V/10V. S(OFF)–+. DD = +15V. 0.3. VSS = –15V. D(OFF)–+. ) C. 0.2
ADG1219 0.6 0.5 V I T DD = 12V S(OFF)+– A = 25ºC 0.5 V 0.4 SS = 0V ID(OFF)+– VBIAS = 1V/10V I V S(OFF)–+ DD = +15V 0.4 0.3 I VSS = –15V D(OFF)–+ ) C I p 0.2 D, IS(ON)++ 0.3 A) I N ( n D, IS(ON)– – IO 0.1 ( E 0.2 CT G JE 0 0.1 N AKA I VDD = 12V E E –0.1 L VSS = 0V 0 –0.2 CHARG –0.1 –0.3 V –0.2 DD = +5V
31 41 0
–0.4
0
V
5-
SS = –5V
4- 57
–0.3
657 06
–0.5
0
0 20 40 60 80 100 120 –15 –10 –5 0 5 10 15 TEMPERATURE (°C) INPUT VOLTAGE (V)
Figure 10. Leakage Currents as a Function of Temperature, 12 V Single Figure 13. Charge Injection vs. Input Voltage Supply
0.3 300 VDD = 5V 0.2 VSS = –5V VBIAS = +4.5V/–4.5V 250 12V SS 0.1 200 A) 0 n ) ( E ns ( 150 AG –0.1 E 15V DS M AK TI E L –0.2 IS(OFF)+– I 100 D(OFF)+– –0.3 IS(OFF)–+ ID(OFF)–+ 50 –0.4 I
2
D, IS(ON)++
27 03 0 5-
ID, IS(ON)– –
5- 57
–0.5
657 06
0
0
0 20 40 60 80 100 120 –40 –20 0 20 40 60 80 100 120 TEMPERATURE (°C) TEMPERATURE (ºC)
Figure 11. Leakage Currents as a Function of Temperature, 5 V Dual Supply Figure 14. tTRANSITION Time vs. Temperature
200 0 I V DD PER CHANNEL –10 DD = 15V 180 T V A = 25
C SS = –15V –20 TA = 25ºC 160 V –30 140 DD = +15V VSS = –15V B) –40 d ) 120 A N ( –50 (µ IO 100 AT –60 I DD L 80 O IS –70 60 –80 40 –90
22
20 VDD = +12V
0
–100 V
5-
SS = 0V
657
0 –110
0 9
0 2 4 6 8 10 12 14 16 10k 100k 1M 10M 100M 1G
00 5-
LOGIC, INX (V)
57
FREQUENCY (Hz)
06 Figure 12. IDD vs. Logic Level Figure 15. Off Isolation vs. Frequency Rev. A | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
