Datasheet ADG1219 (Analog Devices) - 10
Description | Low Capacitance, Low Charge Injection, ±15 V/12 V iCMOS SPDT in SOT-23 |
Pages / Page | 16 / 10 — ADG1219. –10. DD = 15V. VSS = –15V. –20. TA = 25ºC. SOURCE/DRAIN ON. –30. … |
Revision | A |
File Format / Size | PDF / 391 Kb |
ADG1219. –10. DD = 15V. VSS = –15V. –20. TA = 25ºC. SOURCE/DRAIN ON. –30. –40. p (. K ( –50. DRAIN OFF. NCE. S –60. ACI. –70. SOURCE OFF. CRO. CAP. –80. –90
ADG1219 0 8 V –10 DD = 15V VSS = –15V 7 –20 TA = 25ºC SOURCE/DRAIN ON –30 6 ) B) F –40 d p ( 5 K ( –50 DRAIN OFF AL NCE T A 4 S –60 T S ACI –70 3 SOURCE OFF CRO CAP –80 2 –90 VDD = 15V 1 V –100
26
SS = –15V
23 0 0 5-
T
5-
A = 25ºC –110
657 657 0
0
0
10k 100k 1M 10M 100M 1G –15 –10 –5 0 5 10 15 FREQUENCY (Hz) SOURCE VOLTAGE (V)
Figure 16. Crosstalk vs. Frequency Figure 19. Capacitance vs. Source Voltage for Dual Supply
0 9 VDD = 15V V 8 –2 SS = –15V TA = 25ºC 7 SOURCE/DRAIN ON ) –4 ) dB F ( p 6 S ( S –6 5 DRAIN OFF LO NCE N A O T 4 TI –8 R ACI E S CAP 3 SOURCE OFF IN –10 2 V –12 DD = 12V
21
1 V
24
SS = 0V
0 0 5- 5-
TA = 25ºC –14
657 657 0
0
0
10k 100k 1M 10M 100M 1G 0 2 4 6 8 10 12 FREQUENCY (Hz) SOURCE VOLTAGE (V)
Figure 17. On Response vs. Frequency Figure 20. Capacitance vs. Source Voltage for Single Supply
10.00 10 LOAD = 10kΩ T 9 A = 25°C 8 SOURCE/DRAIN ON ) 7 1.00 F p ) ( % V 6 DD = 5V, VSS = –5V, VS = 3.5V rms DRAIN OFF N ( NCE A 5 T HD + V T DD = 15V, VSS = –15V, VS = 5V rms ACI 4 0.10 CAP SOURCE OFF 3 2 VDD = 5V V
10 25
SS = –5V
0
1
0 5- 5-
TA = 25ºC
57
0.01
657 06
0
0
10 100 1k 10k 100k –5 –3 –1 1 3 5 FREQUENCY (Hz) SOURCE VOLTAGE (V)
Figure 18. THD + N vs. Frequency Figure 21. Capacitance vs. Source Voltage for Dual Supply Rev. A | Page 10 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
