Datasheet ADG1433, ADG1434 (Analog Devices)
Description | 4 Ω RON, Triple/Quad SPDT ±15 V/+12 V/±5 V iCMOS Switches |
Pages / Page | 20 / 1 — 4 Ω RON, Triple/Quad SPDT. ±15 V/+12 V/±5 V. CMOS Switches. Data Sheet. … |
Revision | E |
File Format / Size | PDF / 394 Kb |
4 Ω RON, Triple/Quad SPDT. ±15 V/+12 V/±5 V. CMOS Switches. Data Sheet. ADG1433/. ADG1434. FEATURES. FUNCTIONAL BLOCK DIAGRAMS
i
CMOS Switches Data Sheet ADG1433/ ADG1434 FEATURES FUNCTIONAL BLOCK DIAGRAMS 4.7 Ω maximum on resistance at 25°C ADG1433 0.5 Ω on-resistance flatness S1A Fully specified at ±15 V/+12 V/±5 V D1 3 V logic-compatible inputs S1B S3B Up to 115 mA continuous current per channel D3 Rail-to-rail operation S2B S3A Break-before-make switching action D2 16-/20-lead TSSOP and 4 mm × 4 mm LFCSP S2A APPLICATIONS LOGIC Relay replacement IN1 IN2 IN3 EN Audio and video routing
1 00
SWITCHES SHOWN FOR
1-
Automatic test equipment A 1 INPUT LOGIC.
18 06
Data acquisition systems
Figure 1. ADG1433 TSSOP and LFCSP
Temperature measurement systems ADG1434 Avionics S1A S4A Battery-powered systems D1 D4 Communication systems S1B S4B Medical equipment IN1 IN4 GENERAL DESCRIPTION IN2 IN3
The ADG1433 and ADG1434 are monolithic industrial CMOS
S2B S3B
(iCMOS®) analog switches comprising three independently
D2 D3
selectable single-pole, double-throw (SPDT) switches and
S2A S3A
four independently selectable SPDT switches, respectively. 2 All channels exhibit break-before-make switching action that 00
SWITCHES SHOWN FOR
1-
A 1 INPUT LOGIC.
18 prevents momentary shorting when switching channels. An EN 06 Figure 2. ADG1434 TSSOP input on the ADG1433 (LFCSP and TSSOP) and ADG1434 (LFCSP only) enables or disables the device. When disabled, all
ADG1434
channels are switched off.
S1A S4A D1 D4
The iCMOS modular manufacturing process combines high
S1B S4B
voltage, complementary metal-oxide semiconductor (CMOS), and bipolar technologies. It enables the development of a wide
S2B S3B
range of high performance analog ICs capable of 33 V operation
D2 D3
in a footprint that no other generation of high voltage devices
S2A S3A
has been able to achieve. Unlike analog ICs using a conventional
LOGIC
CMOS process, iCMOS components can tolerate high supply voltages while providing increased performance, dramatically lower power consumption, and reduced package size.
IN1 IN2 IN3 IN4 EN
1 10 1-
SWITCHES SHOWN FOR
18 The ultralow on resistance and on resistance flatness of these
A 1 INPUT LOGIC.
06 switches make them ideal solutions for data acquisition and gain Figure 3. ADG1434 LFCSP switching applications, where low distortion is critical. iCMOS construction ensures ultralow power dissipation, making the devices ideally suited for portable and battery-powered instruments.
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2006–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY 12 V SINGLE SUPPLY ±5 V DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
