Datasheet ADG1433, ADG1434 (Analog Devices) - 3
Description4 Ω RON, Triple/Quad SPDT ±15 V/+12 V/±5 V iCMOS Switches
Pages / Page20 / 3 — Data Sheet. ADG1433/ADG1434. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. …
RevisionE
File Format / SizePDF / 394 Kb
Data Sheet. ADG1433/ADG1434. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. −40°C to. Parameter. +25°C. +85°C. +125°C1. Unit
Data Sheet ADG1433/ADG1434 SPECIFICATIONS ±15 V DUAL SUPPLY Table 1 −40°C to Parameter +25°C +85°C +125°C1 Unit
link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 4 link to page 4
VDD = +15 V ± 10%, VSS = –15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. −40°C to −40°C to Parameter +25°C +85°C +125°C1 Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VSS to VDD V On Resistance, RON 4 Ω typ VS = ±10 V, IS = −10 mA; see Figure 25 4.7 5.7 6.7 Ω max VDD = +13.5 V, VSS = −13.5 V On Resistance Match Between 0.5 Ω typ VS = ±10 V, IS = −10 mA Channels, ΔRON 0.78 0.85 1.1 Ω max On Resistance Flatness, RFLAT(ON) 0.5 Ω typ VS = ±10 V, IS = −10 mA 0.72 0.77 0.92 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off) ±0.04 nA typ VD = ±10 V, VS = ±10 V; see Figure 26 ±0.3 ±0.6 ±3 nA max Drain Off Leakage, ID (Off) ±0.04 nA typ VD = ±10 V, VS = ±10 V; see Figure 26 ±0.3 ±0.6 ±3 nA max Channel On Leakage, ID, IS (On) ±0.05 nA typ VS = VD = ±10 V; see Figure 27 ±0.4 ±0.8 ±8 nA max DIGITAL INPUTS Input High Voltage, VIH 2.0 V min Input Low Voltage, VIL 0.8 V max Input Current, IIL or IIH ±0.005 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANS 140 ns typ RL = 100 Ω, CL = 35 pF 170 200 230 ns max VS = 10 V, see Figure 28 Break-Before-Make Time Delay, tD 40 ns typ RL = 100 Ω, CL = 35 pF 30 ns min VS1 = VS2 = 10 V, see Figure 29 tON (EN) 140 ns typ RL = 100 Ω, CL = 35 pF 170 200 230 ns max VS = 10 V, see Figure 30 tOFF (EN) 60 ns typ RL = 100 Ω, CL = 35 pF 75 85 90 ns max VS = 10 V, see Figure 30 Charge Injection −50 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF, see Figure 31 Off Isolation −70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 32 Channel-to-Channel Crosstalk −70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 34 Total Harmonic Distortion, THD + N 0.025 % typ RL = 110 Ω, 15 V p-p, f = 20 Hz to 20 kHz, see Figure 35 −3 dB Bandwidth 200 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 33 Insertion Loss 0.24 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 33 CS (Off) 12 pF typ f = 1 MHz CD (Off) 22 pF typ f = 1 MHz CD, CS (On) 72 pF typ f = 1 MHz Rev. E | Page 3 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY 12 V SINGLE SUPPLY ±5 V DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
